The left side lug is discolored, only in the inside and nowhere else inside the panel. After a closer look, I saw little metal beads.
| Find an InterNACHI certified Maryland Home Inspector (and anywhere else in North America) |
Possible heat damage due to loose connection?
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
Appears to be in a humid area.
If the connections and panel are fine (no corrosion), I wouldn't be concerned. |
just curious Dave what would make you think humid condition from those pictures? |
I was wondering that myself. I don't see anything that would lead me to believe a humid condition exist. I still say it's possible heat damage. Would explain the melted metal specs as well.
I'm sure David has a reason for his thoughts....but He does have me wondering , as i was thinking heat from loose connection also...
Yea I'm sure he has a good reason as well. I just don't see it at the moment.
I'm just guessing David knows the city location is a humid area (94%). Again, just guessing.
Oh my GOD. I need sleep guys. I had read through the post so fast that I had thought he stated "moisture beads", but just noticed "metal beads". I'm off to bed early tonight. I just returned from the US Virgin Islands and a quite nights rest is definitely minutes away. |
| Wooden shingle siding discoloration | wdecker | Exterior Inspections | 4 | 3/26/07 11:07 AM |
| From Inspected to Inspector | jhagarty | Miscellaneous Discussion for Inspectors | 0 | 3/26/07 4:59 AM |
| A BC home Inspector | rcooke | Canadian Inspectors | 0 | 3/25/07 12:05 PM |
| Ceiling discoloration from joists? | dtaylor | General Inspection Discussion | 4 | 8/3/06 12:27 AM |
| Discoloration was caused by a lightning strike! | jtedesco1 | Electrical Inspections | 0 | 1/29/06 5:51 PM |
