View Poll Results: GFCI Poll
Yes 34 51.52%
No 29 43.94%
Don't know...trying to learn. 3 4.55%
Voters: 66. You may not vote on this poll
Old 1/8/09, 9:54 PM
Joe Funderburk, CMI's Avatar
Default Interior GFCI Poll
I know what I would do. How about you? Would you write up no GFCI on a bar wall? The outlet is not in the kitchen, but is within 6 feet of the sink.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/8/09, 9:56 PM
Michael Larson's Avatar
Default Re: Interior GFCI Poll
I would not call it out. It does not serve the counter.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 1/8/09, 9:58 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
With in 6 feet of a utility sink.
Yes I would call it out.
Old 1/8/09, 10:05 PM
Marc D. Shunk's Avatar
Banned
fact is, you can call out anything you want to. You would, however, have no basis in model code or rule of law on which to base your opinion.
Old 1/8/09, 10:16 PM
Marc, you and I disagree on this one. The code states "All 125-volt, single-phase, 15-and 20-ampere receptacles that serve countertop surfaces shall have ground-fault circuit-interrupter protection for personnel."
It doesn't say the outlet has to be in the kitchen. It refers to outlets that "serve countertops". The keyword there is "serve". Could that outlet be used to power a radio on the countertop during a party? Then Disco Dan knocks it into the sink?
Roughly 90% of those outlets in new homes are now protected by GFCI. Those builders must interpret it as required, as I do.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/8/09, 10:30 PM
relliott's Avatar
Guess I better delete this chart you provided.
Old 1/8/09, 10:37 PM
How do you measure 6 ft. from the edge of the sink?
Michael Larson
Hudson, WI
InspectraPro
and
Old 1/8/09, 10:41 PM
I have measured it with a flexible tape. Usually I just estimate. When you have a bar wall with a sink on the other side of it, there is almost always an outlet directly in front of where the sink is, easily within 6 feet.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/8/09, 11:00 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
I would not call that out. The "countertop" above the outlet appears to taper down to no more than 8 inches wide. One outlet can be seen on the kitchen side of the wall (left side of picture). I "assume" (I know, I know) that there is another outlet to the left of the sink serving the countertop, directly above and opposite the outlet of concern. You were there, if you feel it was unsafe, regardless of code, recommend it be upgraded to GFCI for safety.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 1/8/09, 11:04 PM
relliott's Avatar
Robert I think the intent of this rule is that an average plug is 6 feet.
Place a corded appliance at the sink and you get shocked.
Make sense?
Old 1/8/09, 11:07 PM
The bar wall shown is just an example illustration. I see similar setups in 3 out of 5 new homes I inspect. Here's another one from today that I wrote up. Sink on the other side of the opening. Outlet directly below the opening.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/8/09, 11:10 PM
Jeffrey R. Pope's Avatar
Ditto. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Joe you never did say what year or under which NEC applies to either home.
Michael Larson
Hudson, WI
InspectraPro
and
Old 1/8/09, 11:13 PM
Then what does it "serve"? Almost everything you could conceive of plugging into that outlet, except for a vacuum, has to rest on the countertop!
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/8/09, 11:14 PM
My code quote above was from the 2006 IRC.
Theodore Roosevelt
Joe Funderburk, CMI
How long are your poll lines? bchesser Miscellaneous Discussion for Inspectors 16 11/4/08 8:10 PM
Daily Presidential Tracking Poll - 10/19/2008 (McCain Lead Lost) jburkeson1 Miscellaneous Discussion for Inspectors 3 10/19/08 6:16 PM
Washington Home Inspectors Poll sstanczyk Legislation, Licensing & Legal Issues for Inspectors 147 1/30/08 9:30 PM
E&O information poll sstanczyk Miscellaneous Discussion for Inspectors 7 8/19/07 7:54 PM
