Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 1/20/07, 5:50 PM
Joseph Hagarty's Avatar
Joseph Hagarty Joseph Hagarty is offline
Default ITE Panel / Split Main
ITE Split Main Panel
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/20/07, 6:14 PM
Paul W. Abernathy's Avatar
Send a message via AIM to pabernathy Send a message via MSN to pabernathy
Default Re: ITE Panel / Split Main
Joseph,
Are my EYE's starting to play tricks on me.......does not look like a split main panel to me......just looks like a normal ITE panel.
Maybe I just can't see it real well.....
As well as the Grounded Conductor not identified.....double taps..and so on....
AH wait...I see the jump loops............NOW I gotcha
Paul W. Abernathy,CMI,CEI,CEPE
NECŪ Consultant/Columnist
www.twitter.com/ElectricalGuru
- ICC & IAEI Certified Electrical Inspector
- ICC & IAEI Certified Electrical Plans Examiner
- Look for my article in the Nov/Dec 2009 IAEI Magazine
- 2007 "Top Gun" Winner - Mike Holt Enterprises
" visit www.TheElectricalGuru.com Today !"
Old 1/20/07, 6:29 PM
Marc D. Shunk's Avatar
What I think I see there is a regular ITE main lug panel, which should be a subpanel. It appears to be fed with 3 wire, and the grounds and neutrals are not segregated for the branch circuits. The breaker on the upper left appears to have a loose connection, and has heated up a bit over the years. The panel has problems, but it mostly stems from being improperly wired for use as a subpanel. Like Paul, I don't really see a split buss setup here.
Old 1/20/07, 6:30 PM
Marc.....check out those loops about half way down the left side running down and under......interesting.........would ya say
Old 1/20/07, 6:32 PM
DAMN I just hate pictures.........I would WANT to get my EYES in this one and SNOOP around...lol.......Can't say I have seen one do the jumpers like that before......Joseph can I HAVE this picture......
GUess based on the position of the breaker doing the JUMPING to the lower part of the panel...FROM the bottom no doubt...this could be a main panel.......6 throw rule in effect....based on the location of the breaker "ASSUMED" is doing the jumping so not a Sub-Panel then......interesting
Old 1/20/07, 6:33 PM
Looks like a double tap (probably baseboard heaters, if I was forced to guess) and an improper handle tie on those two single pole breakers that they're terminated to. I don't know enough about ITE brand breakers to know if double taps are okay on them or not. I suspect not.
Old 1/20/07, 6:35 PM
Yeah Boy...on that second picture a CLASSIC case of corrosion and causing a hot spot on that conductor.......GOOD catch...and a GOOD reason why HI's are looking in the panels......
Old 1/20/07, 6:37 PM
Marc,
I am talking about the wires JUST above those double taps...NO they are not allowed in ITE panels.
if you follow the ones on the 3rd set down to the left...they appear to go down and UNDER the bottom of the panelboard itself.....now I would LOVE a shot from below that bottom level of breakers...lol.......ahhhh......wish I could be at every inspection these guys do.....and I am am SUCH a freakin NERD !
Old 1/20/07, 6:39 PM
These going under:
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 1/20/07, 6:41 PM
Ah, yes. I see now. It is, indeed, a split-buss panel. Never knew ITE made those. I see very, very little of that brand in my area.
Old 1/20/07, 6:43 PM
On the extreme upper right, there appears to be a knockout lodged sideways, with a single white conductor passing through. Not sure what that's all about. Might be a telco ground.
Old 1/20/07, 6:45 PM
Originally Posted by lkage
These going under:
lol....ahhh...yep we saw those and corrected it in my original post...lol......read my posts fella....lol......just teasing ya
Old 1/20/07, 6:46 PM
lol....I want that corrosion picture.......very nice and the GREEN show up SO nice as well....
Old 1/20/07, 6:48 PM
Just trying to help Mark out...see his post #6...
Larry Kage
231 929 3525
lol.........well you know us electricians and pictures...lol
I will say however Larry...those are some MIGHTY pretty arrows you got there....
National Electrical Code Information and Discussion jtedesco1 Electrical 44 4/18/08 12:43 AM
Subpanel wired as main panel. jlybolt Electrical 15 5/23/07 5:10 PM
Murray Split Main Panel jhagarty Electrical 15 2/18/07 4:26 PM
Main disconnect at meter instead of main panel. OK? kshepard Electrical 14 11/8/06 7:24 PM
Bad electrical problem Pest Guy Electrical 4 1/20/06 10:26 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
