Old 12/13/06, 4:22 PM
WHI WHI is offline
Please Note: WHI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default item in panal
I need to know what this item is. I found it located in the main panal attached to a 20 amp breaker.
Thanks,
WHI
Old 12/13/06, 4:23 PM
Default Re: item in panal
Doorbell transformer, maybe...
20 amp breaker may be a bit much...
Old 12/13/06, 4:34 PM
Michael Larson's Avatar
It shoud not be "in" the panel either.
Old 12/13/06, 4:43 PM
WHI WHI is offline
Thank you for the quick reply. I'll inform the customer of the situation.
Thanks again,
WHI
Old 12/13/06, 5:20 PM
Are you an HI...?....If so consider joining NACHI...we have a great Electrical Entrance Course....
Yes, it is a doorbell transformer and it should not be in the electrical panel.
Paul W. Abernathy
Old 12/13/06, 7:36 PM
cfuoco's Avatar
cfuoco cfuoco is offline
Please Note: cfuoco is a non-member guest and is in no way affiliated with InterNACHI or its members.
I know it shouldn't be in the panel but why?
Old 12/13/06, 7:53 PM
rromoser's Avatar
rromoser rromoser is offline
The secondary low voltage side wiring is not rated to be in the same enclosure as 120/240v wiring. It also has limited heat dissipation inside the panel.
Old 12/14/06, 9:23 PM
Well said Mr. Romoser......with that additional heat.....it could melt insulation.....as stated....cause the transformer to overheat and burn up , maybe catch fire.....and well.....end in a rather nasty situation.
Paul W. Abernathy
Old 12/14/06, 10:52 PM
I don't see the heat as much of a problem as the class 2 wiring inside the panel.
Revision to NACHI COE - Item 6 jbushart Miscellaneous Discussion for Inspectors 27 11/1/06 9:59 PM
