Old 6/23/07, 9:32 AM
John Cahill John Cahill is offline
Default J box history
Any idea of how far back the requirement to keep splices and j boxes accessible?
Is there a way to trace a conductor from a panel to its termination when its behind a wall?
Thanks
Old 6/24/07, 12:14 AM
jkogel jkogel is offline
Default Re: J box history
Knob and Tube splices didn't need junction boxes, so those splices were just taped and tucked away, AFAIK.
Junction boxes must never be covered or made inaccesible, especially important as the splices age, roofs get leaky, corrosion etc., so ...
the Code requirement at the time of wiring is i think irrelavent in this case, I would write up any junction box which was inaccesible.
Old 6/24/07, 1:08 AM
Marc D. Shunk's Avatar
Banned
I've got a copy of the 1896 NEC, and the requrement that junction boxes be accessible is in that edition.
Old 6/24/07, 9:18 AM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
Marc,
The 1896 NEC??? Wow! Do you have that in soft copy?? That would be real interesting reading!!!
John,
To positively trace and locate a cable within any building is very possible. The proper equipment for this can be expensive. Locating the AC cabling while live requires equipment capable of not only inducing a signal on the cable but also being able to trace harmonics of that signal. Higher order harmonics of the signal frequency induced on the cable are less likely to bleedover onto surrounding cables.
Here is a discussion from 3M regarding cable locating techniques. Although the majority of this document is geared toward utility locating the basic concepts apply to almost all cable locating activities. This same equipment can be used inside any structure as well. There are low end cable locator's on the market that will function well if the cables are not live and a signal can be directly applied instead of using induction methods.
http://solutions.3m.com/3MContentRet...ersion=current
</IMG>
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 6/24/07, 9:21 AM
tdietrich1's Avatar
A true electrician geek, Marc.
I ran into another electrician who was so happy so show me 40-50 year old NEC books(the size of a reader's digest). Figured 1800's one's were a single page with three rules: 1. Don't kill anybody. 2. Don't start fires 3. Don't start fires on anyone you killed.
Old 6/24/07, 9:24 AM
Roy D. Cooke, Sr's Avatar
WOW! that goes back further then me or my Brothers Great find .
Thanks MARC.
You continually surprise me and I sure do appreciate your info.
</IMG>
Old 6/24/07, 12:09 PM
Originally Posted by rcooke
Thanks MARC.
</IMG>
Same here. And I enjoy your humor.
Larry Kage, CMI
231 929 3525
Old 6/24/07, 3:23 PM
Thanks all; problems solved. J
The History and Mistory of Grounding jtedesco1 Electrical Inspections 4 1/1/07 3:40 PM
History of the GFCI - AGAIN ! pabernathy Electrical Inspections 7 7/7/06 11:02 AM
History of GFCI development gbeaumont Electrical Inspections 2 1/6/06 8:39 AM
