Old 1/20/09, 8:10 PM
gmartin2 gmartin2 is offline
Please Note: gmartin2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default jumper wire
The local bldg. inspector wants a jumper wire installed across the water meter. Apparently he does not realize that all the water pipes are plastic. (it is a double-wide home) What is the solution?
Geo
Old 1/20/09, 9:16 PM
Default Re: jumper wire
The solution is to point out to the inspector that the piping is plastic. If he still insists on a jumper, then call his supervisor and explain it to him.
This is of course, if you are not trolling us.
Old 1/20/09, 10:58 PM
Marc D. Shunk's Avatar
Banned
When all the piping is plastic, you install the jumper with 1/4" polyethylene tubing for a 200 amp service, and monofilament fishing line for a 100 amp service.
Old 1/21/09, 12:22 AM
gbeaumont's Avatar
Too funny, I never new monofilament was rated that high is that the same for both CPVC and PEX?
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 1/23/09, 12:45 AM
ebretheim ebretheim is offline
Send a message via MSN to ebretheim
The plumbing main service entrance(if metal) is the main grounding electrode. That HAS to be grounded, bonding around the meter is required if the "system" is of a conductive metal. This tends to be a very touchy subject in different jurisdictions. Some electrical inspectors require bonding around the meter if there is even ten feet of copper pipe after the meter. If you want to know what the national electrical code says about it, check article 250(article 250 is very long but its in the first third of it, ill look up the exact article later).
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Neutral bus bar failed inspection Greg Moritz Electrical Inspections 18 1/19/08 1:53 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Proper Marr Connectors for Aluminum Pigtails jskrypka Canadian Inspectors 5 3/25/07 10:41 PM
