Old 10/13/11, 3:58 PM
Mark E. Glowczynski's Avatar
Mark E. Glowczynski Mark E. Glowczynski is offline
Send a message via ICQ to mglowczynski
Default Junction Box for ejector
I'm sorry that my picture from the inspection didn't come out well. The attached image is the type of junction box that the ejector pump was plugged into. I was wondering if it is correct to NOT have the "cleats" that grab onto the stud. It is secured, not well though, be being screwed into the stud. Does it need the "cleats"? Best way to describe what im talking about is where you would actually hammer the "cleats" onto the stud as well as screwing in.
Mark Glowczynski
Right at Home Inspections & Solutions
708 473 5116
Residential Commercial Pre Listing Foreclosures New Construction
Condo Annual Inspections
Illinois Licensed
Proud Member of InterNACHI
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/13/11, 4:02 PM
Default Re: Junction Box for ejector
The best I can show is what I found as far as the "cleats" I am talking about. Sorry if my question doesn't make sense.
Mark Glowczynski
708 473 5116
Illinois Licensed
Old 10/13/11, 4:30 PM
Roy D. Cooke, Sr's Avatar
Its a standard Surface mount Box Not ment to be flush mounted in a wall. We Called them a utility box ... Roy,
should have two screws fastening it to the Wall It should also have a ground screw in the box where the dimple is for the grnd wire.
Old 10/13/11, 4:48 PM
Only had one screw fastening. It will be in report to repair. Thanks!!!
Mark Glowczynski
708 473 5116
Illinois Licensed
Old 10/13/11, 4:50 PM
Jim Port Jim Port is offline
Unmoderated Guest
Roy is correct about it being a surface mount box.
That box may be too small for the usage too.
Old 10/13/11, 5:55 PM
Robert Meier's Avatar
Electricians call those handy boxes. Although they're typically used for surface mounting I see no problem with that box if it's securely mounted to a stud or box bracket and flush with the wall surface. Box fill is usually a problem with them especially when there is a device installed.
Junction box for SEC? clafrance Electrical Inspections 9 6/4/11 10:56 AM
panel enclosures being used as junction boxes dmacy Electrical Inspections 5 2/1/11 5:34 PM
Unsecured Junction box to Furnace lsheehy Electrical Inspections 4 4/20/07 9:02 AM
Wires and Junction at tub mlong Electrical Inspections 8 11/18/06 12:29 PM
Overloaded Junction Boxes and Fill pbennett1 Electrical Inspections 6 11/6/06 4:13 PM
