Old 1/20/12, 8:58 PM
Sean Fogarty's Avatar
Default Just use a jumper
to energize the other side of the sub panel..
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/20/12, 9:38 PM
Jeffrey R. Jonas's Avatar
Default Re: Just use a jumper
Curious and seriously... did you call out that missing knockout?
Old 1/20/12, 9:48 PM
Yes along with the rest of the panel as well.
865-256-5397
Old 1/20/12, 9:55 PM
Thank you. I always wondered if others do as well, irregardless of the other issues.
Old 1/20/12, 10:42 PM
Is the pic sideways or is that the way it was mounted?
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 1/21/12, 8:10 AM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
Is that lamp wire coming out of the bottom left breaker?
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 1/21/12, 11:13 AM
Jim Port Jim Port is offline
Unmoderated Guest
It does look a lot like lamp or zip cord.
Old 1/21/12, 12:34 PM
Jeffrey R. Pope's Avatar
I see this crap all too often, and usually recommend removal or replacement in lieu of "corrections."
It's apparently being back-fed by a single-pole breaker, and the jumper is being used to supply power to (what should be ) the opposite leg of 120V. In addition, it appears to be a sub panel, in which case the neutrals should be isolated from the enclosure. This is most certainly a "home owner" installation.
I always call out missing KO's.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/21/12, 2:18 PM
As do I, but this one would be for a different reason that the typical missing knockout, would it not?
Old 1/21/12, 3:34 PM
I'm not sure I understand what you mean. The missing KO is insignificant compared to the rest of the issues, if that's where you're going...
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/21/12, 4:19 PM
The fact that the missing knock out was against wood also will prevent entry of forgien debris and animals. Like you said the knockout is the minimal.
The whole garage was wired by the previous owner and it showed.
865-256-5397
Old 1/21/12, 6:04 PM
Exactly, and I agree it is a lesser issue, but it is still an issue.
Old 1/21/12, 7:25 PM
Sadly unless I can find nothing else to gripe about the knock outs usually go undocumented. Many times the panels with missing knock outs have far more issues to focus on.
865-256-5397
Old 1/22/12, 2:59 PM
Robert Meier's Avatar
Although the wood does keep stuff out of the KO it doesn't satisfy the NEC requirement where the seal has to be a material equivalent to the enclosure.
110.12 Mechanical Execution of Work.
Electrical equipment shall be installed in a neat and workmanlike manner.
FPN: Accepted industry practices are described in ANSI/NECA 1-2006, Standard Practices for Good Workmanship in Electrical Contracting, and other ANSI-approved installation standards.
(A) Unused Openings. Unused openings, other than those intended for the operation of equipment, those intended for mounting purposes, or those permitted as part of the design for listed equipment, shall be closed to afford protection substantially equivalent to the wall of the equipment. Where metallic plugs or plates are used with nonmetallic enclosures, they shall be recessed at least 6 mm (¼ in.) from the outer surface of the enclosure.
Old 1/22/12, 3:19 PM
Joseph M. Whitt Joseph M. Whitt is offline
Exposed wood can catch on fire. The purpose of the enclosure is to contain the fire.
I would call out a missing ko quicker than I would two neutrals under one screw.
Mike Whitt
Contractor/Instructor
New Spanish version of Grounding Jumper added to Inspection Graphics Library. gromicko General Inspection Discussion 0 9/18/11 11:45 PM
Bonding Jumper Size??? bsmith Electrical Inspections 3 10/28/09 12:19 PM
jumper wire gmartin2 Electrical Inspections 5 1/23/09 12:45 AM
Neutral bus bar failed inspection Greg Moritz Electrical Inspections 18 1/19/08 1:53 PM
