Yesterdays house is mostly K & T, it is a 2 family, and the owner just recently installed GFCI outlets in several rooms.
When testing the device with the buttons, it tests properly, when using a tester, it obviousally shows no ground and will not test. I remember reading back at some point that a 2-prong system can have a GFCI and be wired to operate properly and will not trip if a tester is used. That appears to be the case here. What I am trying to figure out is, if a normal 2-prong system has a 3-prong device installed without grounding it would be considered defective. Why would it not be the same case with a GFCI? The owner (seller) indicated it was his understanding that in using the GFCI device (again which does properly test by the devices buttons) satisfied the code for a 3-prong non-grounded system. Input please. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
An ungrounded Outlet.When three prong receptacles with open grounds are identified and a two-wire system is present, the NEC® currently allows the following methods to be used to resolve the problem:
Filling the ground holes with a hot glue gun or similar method is recogizied up here as an acceptable method.
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
One thing I mention to my clients is that when using GFCI's without a ground conductor, a surge protector will no longer offer much surge protection.
A surge protector sinks the majority of the surge to the ground conductor. So I alway recommend computer equipment to be grounded. Also, do not use a GFCI on a refrigerator or freezer because they tend to trip the day after you leave on a two-week vacation. |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 8:33 PM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 12:29 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 9:31 AM |
