| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
Inspection today found this 100 amp secondary service to a barn from the house. House was built in 1996 barn was buit a few years later. Would you want your kids playing here?
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
What type of wire is that, doesn't look like thhn. It could be wire trough wire, I forget the name, but I would not have a problem with it.
http://www.alphawire.com/PAGES/awis1.cfm
http://wesbellwireandcable.com/TrayCable.html can't quite find what i am looking for. Last edited by bkelly1; 10/27/07 at 7:55 PM.. |
That's not cable. Those are conductors, and SHOULD be in conduit in that installation.
Could very well be small URD, which IS direct burial rated but MUST be protected where exposed. Good call Scott. |
Could also be SJ wire. None the less it should be protected.
Sorry getting to this one late...I agree with the SPEEDSTER on this one...more than likely direct bury rated wires that came into the dwelling from the conduit and then they did not continue it to the enclosure for the barn. They indeed need to be protected.....
Also looks like they used Plumbing Pipe on what they DID protect...hmmmm Paul W. Abernathy,CMI,CEI,CEPE NECŪ Consultant/Columnist www.twitter.com/ElectricalGuru - ICC & IAEI Certified Electrical Inspector - ICC & IAEI Certified Electrical Plans Examiner - Look for my article in the Nov/Dec 2009 IAEI Magazine - 2007 "Top Gun" Winner - Mike Holt Enterprises " visit www.TheElectricalGuru.com Today !" |
Direct bury wires there, and yes DWV pipe used. I see that all the time here. Just could'nt believe they left it exposed under the deck like that. 3' of crawl space there. The couples grand kids would love that area. Out the back of the deck it sloped down to the river. Kids would have been there all the time. Here is what else was at the back of the deck.
This is classic DIY stuff.
They know enough to make it work, but not enough to make it safe. |
well...hopefully when you see Plumbing Pipe being used for electrical conduit...you call that out also....if you see it all the time we have a serial DIYer on the loose.....lol
Actually if that is really USE I would question the fact that it is not "outside the building"
I hope you didnt put that comment in your report as stated on the photo. That comment will probably end up filling some attorneys pocket. The reason I say this is because you have given an opinuanated "cure" to the defincency that you found. I ask u this.....You stated "should be in conduit" So if I as a homeowner decide to have this repaired and use the wrong type of conduit and my kids decide to play there and get electricuted..Are you responsible for this???? I would think the proper statement here would be that the condition does not appear to be compliant with industry standards and should be further evaluated by a proffesional licensed electrical contractor.
Paul Pendley Premier Property Inspections 866-458-8516
| Going To Jail For Jerry's Kids! | jcampbell | Charitable Organizations | 2 | 10/22/07 10:27 PM |
| Play: "Spot the problems" | pbolliger | HVAC | 24 | 11/16/06 10:15 AM |
| Learn and play games! | phinsperger | Education | 0 | 6/8/06 9:21 AM |
