Hey Guys,
What kind of tester do you use... I am presently using GB GFCI tester, its a great tester, but now since I am doing more new homes that have AFCI's, I was wondering how many of you use the Suretest by IDEAL... IDEAL puts out some great testers, I was just wondering what everyone uses, and the pros or cons with such devices... And do the newer testers in the $100 - $200 range, really assist in finding additional electrical defects???? |
Justin,
Technically speaking.....your tester is fine in regards to basic testing and in regards to GFCI or AFCI's.....they should first be tested at the device itself be it a breaker or receptacle unit. The GB Testers are fine but they will not show you about a "bootleg" ground which possibly homeowners showing their poor handy work..... Now if you are into doing voltage drop and REALLY understand what it means other than just making notice of perfectly ok situations...it could get you into more trouble than it is worth..... As for the basics....the GB GFCI tester is ok....but the Suretest ideal Tester is a step up...... The downside is they are not cheap...the upside is they give a more professional appearance and another level of testing ...in that you can test the GFCI and AFCI via the actual device as the manufacturer recommends but also you get to try them again via the tester...which offers another level of inspection. If you just use your tester to verify....understand the age of the house and look around for a mixture of 2 pring and 3 pring outlets...just understand that a bootleg could be possible.......but if you are testing and do use the actual breaker or receptacle for testing the device....then the Sure test Ideal is an expensive addition....BUT in my mind and for what I do ( enhanced Electrical Inspections ) it is worth it. Paul W. Abernathy |
Where do we draw the line should we buy the expensive air flow testers to see how much air comes out of each register and how about a water flow test on each tap and should I get a tester to see ?, and on it goes show many hours can I spend on a home inspection . I like KISS Keep it simple stupid . It fits me just fine thanks . Leave the specialized testing to the proper trades . Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Aww...roy.......you just are tight...lol.......you Canadians...and your colorful funny money...lol
Paul W. Abernathy |
See you soon I hope Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Justin
I am on my 3rd Ideal sure test analyzer in just over 1 year. There is a defect in the extension cord & pins. It loosen up after only a short time. The product is warrantied but isnt reliable in my opinion. I only use when I suspect a bootleg ground or if I note in the panel only 2 wire system I may go back & re check an receptacle with the NOT SO SURE Ideal Analyzer. Hope this helps. Dave Last edited by dmacy; 11/6/06 at 5:24 PM.. |
Great info. thanks everyone....
I used to use the Ideal 165, but had the same problems that everyone was having with them. I recently went to the Tasco Inspector II. It is a little bit bulky, but I like it.
I've been using the SureTest for quite some time now. Just like any other tool, it can stop working or wear out. That's why I have three of them.
SureTest will replace the unit for free if/when it stops working (@ $350 a pop, it's nice to know they'll replace the unit). I also carry the 3-light testers, a non-contact voltage tester and Fluke (voltage continuity and current tester). IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I use the Fluke and the three light tester. The Fluke to spot the bootleg grounds and unloaded voltage. Fluke is 20 plus years old and never been serviced - Good meter -
I do have a modified old power strip that I use that I hook the Fluke and the three light tester to. Saves testing time and it helps out when some one puts a socket in a spot where I can't get the tester into. Like sockets in the overhead of a boat house I do carry a resistive load (head gun) to load questionable ckts for voltage drop testing. Very seldom use it and I do charge $75.00 extra to test for voltage drop at a "representative" number of sockets I do not like the Suretest. Basic test equipment is very hard to beat rlb rlb |
lol.....well give me New technology anytime...lol
Paul W. Abernathy |
Paul
That is why I bought the Fluke 20 years ago BTW -- I knew that the company was good Still waiting for some good new tech stuff for my Xmas list ---(thermal cameras etc.) --- |
lol....ME TOO..hope SANTA is good to us BOTH..
Paul W. Abernathy |
| Outlet Reading | nbhi | Electrical Inspections | 15 | 5/12/07 6:07 PM |
| Idiot Light Tester (3 Bulb) | bkelly2 | Electrical Inspections | 17 | 2/9/07 1:40 AM |
| Testing a dryer outlet | acox | Electrical Inspections | 14 | 7/27/06 10:51 PM |
