Old 11/28/08, 4:51 PM
lprinzi lprinzi is offline
Default Kit counter spacing
Does anyone have an idea when the requirement for outlet spacing on the kitchen counter went into effect. The inspected house was built in 1987 and definately does not meet the current requirements, but I'm not certain what was in effect at the time of construction.
Lou Prinzi
First Choice Building Inspections, Inc.
www.FCBIJax.com
(904) 223-0068
Old 11/28/08, 5:01 PM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is offline
Default Re: Kit counter spacing
I don't think its a good idea to quote codes! especially in that instance. But I don't know
Rick Kie
Old 11/28/08, 5:05 PM
Thanks. I don't quote "codes" but list the requirement rather as "proper building practice" and explain it to the client that way. Either way, the requirement still stands and I need to let the client know. Any idea on the effective date?
Lou Prinzi
www.FCBIJax.com
(904) 223-0068
Old 11/28/08, 6:21 PM
Bob Elliott's Avatar
I would just point out how many there are verbally during the inspection as it may not be a big deal.
Is there only one?
Old 11/28/08, 6:26 PM
Stephen W. Stanczyk's Avatar
Requirement? Not a word I would use. If it wasn't required when the house was built, it's not required now. Recommended? yes. Required? no.
Stephen Stanczyk
Old 11/28/08, 7:10 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
1984 NEC 210-52 (b) requires a recepticle outlets shall be installed at each counter space wider than 12".
I don't quote code in my report but referr to it when questioned.
www.mauihomeinspections.com
Old 11/28/08, 7:16 PM
Unmoderated Guest
Long before 1987, I can tell you that.
Old 11/28/08, 7:36 PM
Unmoderated Guest
In 1959 the code for the kitchen was the same as the rest of the home (6 feet). The next code book I have is 1975 and it requires the counter space wider than 12" rule.
Old 11/28/08, 7:53 PM
Thanks for the feedback. As info, we're all doing code inspections whether it's admitted or not. Just think of all the items you report on... the majority of them are covered under one code or another. As a rule, I never do mention the word "code" in my reports (and have been doing so for 13 years) and agree none of us should. However, any known violations are pointed out as issues to be addressed as "proper building practices". This particular counter had only one outlet in a 5 foot run and none on the adjoining counter. Thanks again for the feedback.
Lou Prinzi
www.FCBIJax.com
(904) 223-0068
Old 11/28/08, 8:33 PM
David P. Valley's Avatar
It's pretty simple to simply recommend upgrades without referring to code. If I feel additional outlets will be needed in a specific area of a home, I simply recommend additional outlets.
Old 11/28/08, 9:31 PM
Joe Funderburk, CMI's Avatar
Like this, David?
"There are not as many outlets serving the kitchen counters as would be required by current standards, and you may wish to consult an electrician about the possibility of adding more."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/29/08, 6:17 AM
Originally Posted by jfunderburk View Post
Like this, David?
Perfect, Joe.
Old 11/29/08, 8:26 AM
nwagner's Avatar
nwagner nwagner is offline
Ditto.
It's common sense that the electrical service needs upgrading in many of the older homes in my area. For example, many original services on the +75 year old homes only have two receptacles for the entire kitchen and one of them is for the refrigerator. Plus, the kitchen circuit includes the lights and two adjacent rooms. No parties object to my recommendations for upgrading the electrical service when I go over my typical themes of newer refrigerators drawing up to 15 amps for defrost cycle, many microwaves drawing over 10 amps, the conductors possibly of reduced capacity due to over 50 years of wear and tear, the safety hazards of receptacles near water not having GFCI protection, the problems with using extension cords, etc.
Its common sense, something codes don't convey to the average Joe.
Granite Counter Tops Emitting Radon tchristopher Ancillary Inspection Services & Additional Topics 37 5/7/09 1:25 PM
Outlet behind cooktop srowe Electrical Inspections 12 5/17/08 2:02 PM
Elec. stove/wall spacing jwalker6 Canadian Inspectors 5 4/16/07 5:09 PM
