Is a light above a kitchen sink a requirement(NEC)?
First time I've not seen one installed. Thanks in advance. |
| Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Anyone??
I didn't find code in the nec requiring over sink lighting, but www.inspectopedia.com has recomendations for lighting
Insight Inspection Services LLC 239-410-1378
No, there is no specific requirement in the NEC for a light above the sink.
Licensed Master Electrician, Kentucky #ME 6509 PHII Certified Inspector,#LMH30000017878 EPA Universal Certification Section 608, #0028673113930 Member, National Fire Protection Association |
Code or not I still include the fact in my report.
Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat |
I don't have a light over my sink. Not really an issue for me.
Greg Mathias, CCHI Journeyman Carpenter Level I Thermographer Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
I don't have one either! It must be an American thing. My sink is on the south side of the home with a big window so that might be the reason why.
THE RIGHT TRAK CIAQP, IAC2 Board Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq apoteyes@gmail.com Cell: 705-971-2096 Ph : 705-946-2676 |
Lighting above the sink and/or under the counter would all fall under the heading Task Lighting. In some circumstances, they are not required due to the adequate lighting provided at the ceiling area adjacent to the sink area.
I have one, but hardly use it, unless a certain task requires the additional lighting. JMH
LEED Green Associates Inachi US Member of the Year Award 2009 Best Home Inspector Software http://co.nachi.org/inachiawards |
That generally applies to Commercial and Hospitals.
Can you provide the training link Marcel for TASK LIGHTING as I have not seen it for some time? http://www.tasklighting.com/ THE RIGHT TRAK CIAQP, IAC2 Board Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq apoteyes@gmail.com Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 12/28/12 at 12:40 PM.. |
Training Marcel was provided through CE's but I can't find the info.
I hope you guys are inspecting the halogen wiring .
It can be a very big issue finding 110 going through holes in the cabinets or transformers buried in walls. Never heard of code requirements for residential sink lights in my life. |
Neither have I Bob.
Agreed Bob and I had this same issue not more than 3 weeks back.
The trick with our older eyes is to take a picture of a bulb socket on the puck as it shows you if bulbs are 12v or 110v so you know if there is a transformer.
| Plumbing vent under kitchen sink | jarnold3 | Miscellaneous Discussion for Inspectors | 5 | 8/18/12 1:13 PM |
| Composite granite kitchen sink ... good choice? | Bill Featherstone | Plumbing Inspections | 6 | 1/8/08 11:03 PM |
| waste pump under kitchen sink | tjansson | Plumbing Inspections | 3 | 5/11/07 2:15 PM |
| venting the kitchen sink | kblair1 | Plumbing Inspections | 57 | 12/8/06 3:37 PM |
