If a kitchen (new build) only has one reset GFI does that mean there is only one kitchen 20 amp circuit?
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Not necessarily. The only way to verify this is to attempt to trip the other outlets.
Some may be on a different circuit and may not trip. If you attempt to trip outlets near the sink area and the GFCI (with the buttons) does not trip, then you have another circuit or they may be outlets that are not properly located on the load side of the GFCI. |
There should be 2 GFCIs, one each for the 2 required 20a small appliance circuits. One might be in the pantry, breakfast nook or dining area if there is counter space there. You might also have a GFCI in the panel serving one.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Kitchen floor slopes?? | crichiii | Structural Inspections | 6 | 5/29/07 7:24 PM |
| Lack of circuits | dmacy | Electrical Inspections | 30 | 5/16/07 9:04 AM |
| Preemptive Spark Helps Find Electrical Short Circuits In Airplanes | mbledsoe | Electrical Inspections | 0 | 6/21/06 2:30 PM |
