| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
Is this a version of knob and tube?
The wires are insulated. |
Yep. That would be an "open-conductor support."
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff,
How much of an issue is the insulation packed around it? I would think it would contribute to conductor overheating. |
It's not allowed. I would say that it's a "substantial" issue which should be corrected.
394.12 Uses Not Permitted. Concealed knob-and-tube wiring shall not be used in the following: (5) Hollow spaces of walls, ceilings, and attics where such spaces are insulated by loose, rolled, or foamed-inplace insulating material that envelops the conductors -- IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Buried Knob & Tube | brepanshek | Electrical | 14 | 2/15/07 10:12 AM |
| K&T splice. | egarcia1 | Electrical | 13 | 2/3/07 7:36 AM |
| Insulated Knob and Tube? | scosta | Electrical | 6 | 2/3/07 7:22 AM |
| Knob and tube | wblakey | Electrical | 17 | 11/14/06 8:41 PM |
| Knob and tube: heat's the main problem? | kshepard | Electrical | 21 | 6/27/06 10:51 AM |
