Old 4/2/07, 4:48 PM
David C. Macy's Avatar
Default Knob & tube & romex connections
This 1918 home had the basement re-wired with 20 amp romex and they spliced inside junction boxes to older knob & tube wiring. The 1st & 2nd floor wiring is all older K & T. Isnt the older K & T 15 amps? Some of the splices are outside of the junction box.
I called out an electrician to review all older K & T and the connection points.
Also at the main panel the connection point of the ground wires appeard to be improper. Sloppy work at the nuetral & ground connections. Isnt that one nuetral improperly crossing the hot bus bar?
ID:	10484   knob-and-tube-and-romex-connections-94807-030-small-.jpg.jpg
ID:	10485   knob-and-tube-and-romex-connections-94807-022-small-.jpg.jpg
ID:	10486   knob-and-tube-and-romex-connections-94807-035-small-.jpg.jpg
Old 4/2/07, 5:31 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: Knob & tube & romex connections
David,
is that asbestos tape on the duct work?
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 4/2/07, 5:52 PM
Originally Posted by bgraham
David,
I do belive it may be. I called it out. I was more concerned about the 5 2x4 as the main house beam. I need to see what the bearing weight is compared to 3 or 4 2x8.
Old 4/2/07, 5:57 PM
David P. Valley's Avatar
Knob & Tube is allowed to be spliced into Romex but it must be done inside a junction box. The wire caps are an improper spliced connection if they are not placed inside a junction box.
"Click to Enlarge"
Attachment 10496
Buried Knob & Tube brepanshek Electrical Inspections 14 2/15/07 10:12 AM
K&T splice. egarcia1 Electrical Inspections 13 2/3/07 7:36 AM
Insulated Knob and Tube? scosta Electrical Inspections 6 2/3/07 7:22 AM
Knob and tube wblakey Electrical Inspections 17 11/14/06 8:41 PM
Knob and tube: heat's the main problem? kshepard Electrical Inspections 21 6/27/06 10:51 AM
