This is why home owners shouldn't do their own work.
Scott A. Figert www.sfigert.com www.nachi.org NACHI #06042595 Figert Building Inspection, Ltd. (419) 399-4472 Office & Home Sweet Home |
Stuff enough crap in there and sooner or later it will make a contact and become electrified!!!
They forgot to install at least a half of a box of wire nuts, 3 rolls of electrical tape, the spliced down extension cord, and the set of jumper cables. Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers Last edited by sgilligan1; 7/31/07 at 8:58 PM.. |
It may be in there! - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
You don't really want to see the whole panel. If you want to see some more of his fabulous wiring. Go to the General Inspection Discussion and look at
"Tankless & BRAINLESS" Scott A. Figert www.sfigert.com www.nachi.org NACHI #06042595 Figert Building Inspection, Ltd. (419) 399-4472 Office & Home Sweet Home |
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
now someone's gotta go through that mess to get to those neutrals and grounds that are terminated together. Actually, here's a question for all you electricians....why do you (and I use that term collectively speaking) put neutrals and grounds together when there is plenty of extra room on the buss to separate them? I can't tell how many times I've seen a panel in which the grounds and neutrals are shared and there are open screws right next to the double-up! Just curious.
For the longest time the restriction about both the neutral and ground under the same screw was in the listing and labeling of the panel. The Code recognized that most do not read these instruction so they were spelled out in the Code Article.
As for why it is done I can only guess that is due to laziness, ie both wires are together in the jacket and it makes it easy to loosen one screw and terminate both wires in one motion. |
Lets pick on plumbers cracks for awhile. Leave us sparkys alone. Some of us do good work.
From the looks of that panel I doubt a "lectrician" did it.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
As Paris Hilton would say, "that's hot!"
John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
Richard A. Hayes is a non-member guest and is in no way affiliated with InterNACHI or its members.
Knot all DIY panels look like that one...a few DIY'ers take pride in their work.
This one OK? ![]() Richard |
It's OK if you rotated the picture 90 degrees.
(note what looks like firring strips and not traditional studs) Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Ok..how about this pic-
The original panel looked like the one started in this thread AND was mounted over a TOILET. No- I'm not kidding. AND the previous owner at one time tapped (was not connected when I tore out the wall-and terminated w/ electrical tape in the crawlspace!!!) the power line in the wall before the meter to power his AC compressors. He was a Doctor w/ 5 kids... The piture is after the mirrors and the cultered marble tub was removed. And yes-they had put sheetrock over the windows BEHIND the mirrors. The toilet is long gone- it's m now a laundry room. ![]() ![]() ![]() ![]()
I found this one in South Dakota. I figured I could just move that box to get working spce ... nope.
| E-Mail I Got - Quite Nice.... | pabernathy | Miscellaneous Discussion for Inspectors | 4 | 12/14/06 2:56 AM |
| Very nice Panel | cbuell | Electrical Inspections | 2 | 10/8/06 3:48 PM |
| Have A Nice Day | jpope | Miscellaneous Discussion for Inspectors | 3 | 3/3/06 9:50 PM |
