The label was missing from panel.
Can someone tell me if they no the manufacturer? Thanks |
I'm not sure about the one that's missing it's cover, but the other is an FPE Stab-lok. . .
Old Murray or Arrow/Hart???
I would put money on a GE panel. they used a main lug panel and converted it to a main breaker (Cutting Cost?), is that aluminum branch circuits I see
It appears at the Neutral bar there are possibly some aluminum and also on the left side of the breakers that is why I was asking the question to clarify that's all
There were no other aluminum wires. All copper. |
Thanks
For beer $, I could go searching thru my files for a pic of one of those with a label. How badly do you need the info?
That black lead upper left breaker tapped with the blue copper is not Al? John Kogel www.allsafehome.ca |
Beer sounds good. What kind do you prefer. |
Knowing you over the years I am sure you explained to them all the issues they face.... Advice I would give to anyone who ends up with a panel they can't find a manufacturer for....just state that clearly and move onto the defects as it is far better to deal with the defects than trying to pin down maker. With all the colors arranged in that panel......and with Mr. Pope not knowing since he has ALOT of experience with the colorful zinsco's....chances are it is just better to put unknown or unable to determine. Paul W. Abernathy |
Paul
It is not often I find the label missing. I did defer the panel to an electrician due to the missing label, the improper taping of the FPE sub at the main SEC and breaker and I noted the improper connection of the aluminum ground and neutral. There may of been more issues but I think the client understood. (Or I hope so) No more room and need a new main panel, or at least have the electrician advise to correct. Thanks for the kind words. |
Click on each pic to get a bigger version of it. Then you can tell what kind of pasta it is 2008 InterNACHI Member and Innovator of the Year HOME INSPECTOR PRO HOME INSPECTION SOFTWARE NOW ONLY $499 ($15O OFF!!) Easy to use, customizable Home Inspector Software that runs on Windows, Mac, Android & Linux InterNACHI members receive 3 months of FREE home inspector website hosting List yourself in our Home Inspector Directory Free Watch our NACHI.TV Software & Search Engine Optimization videos! Help@HomeInspectorPro.com Last edited by dmaricic; 9/6/08 at 11:19 PM.. |
(DM knows this, but he won't mind sharing the glory) Last edited by jkogel; 9/6/08 at 8:28 PM.. |
| Miller AC (Blank Label) | gkoehl | Inspecting HVAC Systems | 2 | 3/9/07 9:56 AM |
| Water Heater label missing | rnewman1 | Plumbing Inspections | 3 | 9/19/06 6:15 PM |
