Old 5/14/07, 12:30 PM
David C. Macy's Avatar
Default Lack of circuits
The main panel was replaced in this 1930 home.
It appears to be lacking the proper amount of circuits.
I was looking at the code check book and is there anything that states the minumum amount of circuits at a main panel.
These 1st time buyers are being led to believe they have an updated service.
The home lacks receptacles in the bedroom. (1 in each room was observed)
Knob & tube was present
The kitchen is outdated and had only 1 receptacle that was installed in the door.
The main panel has only 3or 4 breakers for the entire house. Excluding the air.
No GFCI protection.
Fixtures wear rusted, dated.
Any thoughts on this upgated service?
Thanks
Old 5/14/07, 12:59 PM
jking2 jking2 is offline
Default Re: Lack of circuits
Wow! I wonder how anyone is not Amish can survive with only one receptacle in the kitchen. Do the owners have a refrigerator or an ice box? How is a receptacle installed in a door?
The porcelain knobs and tubes in the 2nd photo look dark like they have soot on them. Has this house had a fire?
Jim King
Old 5/14/07, 1:03 PM
Current code probably means nothing since this is an existing house but the general rule is you should be able to reach a receptacle from anywhere in a room at the wall with a 6 foot cord and not string it across a doorway or fireplace. That was not the standard as recently as the early 60s so it is not unusual to see places where this is not true. One receptacle in a room is not uncommon in old houses. The other place where it shows up is a lack of 20a receptacle circuits serving countertops in the kitchen (2) and bath (1).
They would also require GFCI protection. My guess is this old house needs a serious electrical upgrate.
Old 5/14/07, 1:06 PM
What bothers me is this is a typical type house were the first time buyres are told that this house has been upgraded as they installed a new panel.
I told them that they need an electrician to update the branch circuitry and I opened there eyes as they were misled by the agents.
They have a new born on the way. I don't want the responsability of a infant being electrocuted due to extension cord wiring and other potential concerns of an older system.
Old 5/14/07, 2:22 PM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
In the UK, 3 or 4 breakers for the entire house is perfectly normal. But then we use fuses in each and every plug, so a device can blow a fuse without tripping the whole circuit. Come on America. Catch up!
Old 5/14/07, 4:14 PM
Ian, it would not be a case of catching up as much as totally changing our wiring philosophy. You folks have 230v ring circuits and we use radial circuits at half the voltage. You also have fewer transformers serving more homes each. I doubt most of your homes have 48 kva services either but that is pretty much standard here with bigger homes being twice that. The differences go on like this quite a bit.
Old 5/14/07, 4:50 PM
Marc D. Shunk's Avatar
Banned
Sounds like the service was, indeed, updated. You apparently are confused on what the term "service" means. The branch circuits, however, do not appear to have been updated.
Old 5/14/07, 7:41 PM
That's how I read it, too.
Larry Kage, CMI
231 929 3525
Old 5/14/07, 10:08 PM
Unmoderated Guest
I truly understand your concern, but how could you EVER be considered "responsible" for such a thing????
You just report the lack of "modern" circuits; quantity and otherwise.
Because the house is old is not your fault. Because previous owners never added circuits is not their fault either. It is simply fact. Obviously the previous owners never needed to add circuits. It is not mandatory that they do.
As Marc stated, the service and branch circuits are totally different things. Many folks are mistaken in their belief that when they are told the "Service has been updated", they think the house was re-wired.
Old 5/14/07, 11:29 PM
William J. Decker's Avatar
Most local codes in our area hold that if the 'service' (generally taken to mean raising the service amps or replacing the service equipment) is upgraded, then ALL the house's electrical equipment (breakers, wires, conduit (read: take out knob and tube), receptacles (read: current standards with regards to GFCI and AFCI and receptacle placement, distance and number) must also be upgraded.
In other words, if a licensed electrician changes out the SE panel, everything downstream must also be upgraded to current local code standards.
Must be a union thing .
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 5/14/07, 11:51 PM
Unmoderated Guest
William, if that is in fact true, it is an absolutely absurd requirement IMO.
I bet it could also be proven illegal to enforce.
Old 5/15/07, 12:28 AM
Banned
Originally Posted by wdecker
Most local codes in our area hold that if the 'service' (generally taken to mean raising the service amps or replacing the service equipment) is upgraded, then ALL the house's electrical equipment (breakers, wires, conduit (read: take out knob and tube), receptacles (read: current standards with regards to GFCI and AFCI and receptacle placement, distance and number) must also be upgraded. .
Got a link? Not calling BS, because I can believe anything from the Chicago area. I'd just like to read more about it, is all.
Old 5/15/07, 4:54 AM
Russel Ray's Avatar
I would, too. That would make some interesting reading.
Old 5/15/07, 9:44 AM
mthomas2 mthomas2 is offline
At those connections to the K&T running into the panel at top center secured to the box in any way, or just routed through the knock-out? Around here (assuming that it was allowed to stay) most AHJs would require that the K&T terminate at junction boxe(s), with modern (NM or wire in conduit) run from the junction box to the panel in an approved manner.
Old 5/15/07, 10:41 AM
Joe Funderburk, CMI's Avatar
"There are not as many outlets as would be required by current standards, and you may wish to consult an electrician about the possibility of adding more."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Multi-Branch circuits Matthew Hopkins Electrical Inspections 3 6/28/07 7:18 PM
Article 240 : Overcurrent Protection Article pabernathy Electrical Inspections 0 5/23/07 11:40 AM
Preemptive Spark Helps Find Electrical Short Circuits In Airplanes mbledsoe Electrical Inspections 0 6/21/06 2:30 PM
