Old 2/15/10, 9:23 PM
Bob Arena Bob Arena is offline
Default Laundry Room Wiring
Please comment on this laundry room wiring...thanks.
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/15/10, 9:28 PM
Default Re: Laundry Room Wiring
I can't tell what the material is...
Did you take the pic?
What is the material/conduit?
How do you see it?
Larry Kage, CMI
231 929 3525
Old 2/15/10, 9:29 PM
Bob Elliott's Avatar
I might recommend GFCI.
Will let others comment on the conduit.
Old 2/15/10, 9:35 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is online now
Is the conduit rated? What does the back of the box look like? Recommend GFCI.
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 2/15/10, 10:00 PM
Jim Port Jim Port is offline
Unmoderated Guest
Looks like non-metallic flex conduit. Typically used for AC compressor wiring from the disconnect. Article 356 of the NEC covers this. I don't think it meets the uses permitted in 356.10, but also don't see it prohibited by 356.12.
Looks like the first strap is too far from the box too.
If the receptacle is within 6' of a laundry tub it would require GFI under the 05 or later NEC.
Evaluating your home's wiring system mcyr Electrical Inspections 0 12/30/09 1:31 PM
Duct from above furnace in laundry room..... shand Inspecting HVAC Systems 6 7/1/09 10:58 AM
Common wall of garage is Laundry room / firewall ? dnasser Interior Inspections 14 6/26/09 11:57 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
