Old 4/25/11, 8:29 PM
Bob Elliott's Avatar
Default Lesson learned
My client happened to be an Electrician and he decided to open a few receptacles while I was going through the kitchen.
I normally just check with three light tester but may decide to upgrade after his find.
Check it out here.....
[ATTACH]lesson-learned-electric-false-ground-test.jpg[/ATTACH]
Note: pay attention to him confirming that the conduit is open and not capable of being used as a ground unless the break is found.
Turns out he could not locate the issue while there as it may be in a wall.
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/25/11, 8:35 PM
Tim Spargo's Avatar
Default Re: Lesson learned
Many of the items we check for can be sampled with the Sure Test.. easy
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 4/25/11, 8:39 PM
YEP,I may go spill for the $200 or what ever they are now.
I do not get the McMansions ,so never bothered since I have little worry on voltage drops in Bungalows.
Old 4/25/11, 9:20 PM
Robert Meier's Avatar
We cannot see the meter display in the photo. Are you saying that the conduit in the wall was not grounded?
Old 4/25/11, 9:30 PM
Tim Spargo's Avatar
Robert... pic 2 of 2 looks like a "bootleg" in my book. The neutral comes up and around the ground screw. Pic just threw ya is all.
Tim Spargo
661-317-5770
Old 4/25/11, 9:31 PM
Jeffrey R. Pope's Avatar
They're closer to $300. False-grounds show up clear as day.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/25/11, 9:33 PM
Christopher Currins's Avatar
Does your insurance cover him Bob?
Christopher Currins
Certified, Licensed
Old 4/25/11, 9:42 PM
Often times, the "bootleg" isn't that obvious. You will also find instances where the receptacle appears to be wired correctly and the connection to the neutral is a junction-box upstream of the outlet.
This is my standard narrative for this condition.
Several of the interior receptacles tested to have a false, or "bootleg" ground. This is a potentially hazardous condition where the neutral conductor is also being used as the equipment-grounding conductor, which could introduce voltage onto what would normally be non-current carrying components. This condition should be evaluated by a qualified electrician, and serviced accordingly.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/25/11, 10:02 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
I know you mentioned it before. Which tester do you use?
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 4/25/11, 10:06 PM
Correct.
He said there must be a break in the conduit.
Bear in mind we do not use ground wire in the Chicago area much on branch circuits since conduit is required with only short 6 foot runs of BX allowed by code.
Old 4/25/11, 10:09 PM
Yeah ,my funeral insurance.
He was doing this without me knowing it but lets not get into thread drift.Yesh.
Why are you wanting to sell me some?
I of course called the police and had him arrested immediately.
Old 4/25/11, 10:10 PM
Ideal SureTest 61-165
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/25/11, 10:11 PM
There are brands that compete at much lower prices ,are there not Jeff?
Old 4/25/11, 10:14 PM
Just busting your chops. I find it a challenge sometimes to keep my clients from participating.
Christopher Currins
Certified, Licensed
Old 4/25/11, 10:17 PM
Hey it was great to have him there.
I love clients working along side me and usually the guys do as I often take a educational approach and everything in the report is very clear.
Nobody ever calls and asks what my report means.
Never happened yet and hope it never does.
Personally, I am not the jumpy everyone is out to sue me type.
Driving lesson wdecker Miscellaneous Discussion for Inspectors 1 11/19/08 11:12 PM
Home inspector finds faults, but also gives buyers a lesson jhagarty Miscellaneous Discussion for Inspectors 2 2/20/06 7:25 PM
