Does anyone have a table/chart available?
thanks, Peter |
I don't know if such a list or table exist, but in my opinion, it would all depend on the quality of the Product and the usage of it. Those two variables would dictate as to how long something would last. No different than a car. Depends on make, quality, useage. Some have a car for ten years like me and some have a car for two years. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I have seen a chart [somewhere] but I would think it would just be a guide. I fully agree with your above post. </IMG></IMG> 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Thanks Mario;
The reason for what I have said is due to what I have seen in the past. I have renovated College Libraries that had receptacles 25 years old and still like new. I have renovated College Dormitories where equipment and receptacles were in a dangerous condition after only five years. I would be curious to see that list if it exist and am sure that it would only be a guideline as you mentioned. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
This is timely... there was a note in the old versions of the National Electrical Code almost 50 years ago with respect to the lifespan of wiring. I don't know why it was ever removed. It might be interesting for a the home inspector to know that over 50 years ago, the code did recognize that wiring had a limited lifespan. The code read as follows:
1953 NEC, Chapter 10, Table 2, Note 10- 10. Deterioration of Insulation. It should be noted that even the best grades of rubber insulation will dete- riorate in time, so eventually will need to be replaced. |
It's hard to say when a switch will fail. Some were definately better than others. Many of the pushbutton switches from the 20's are still in service, and may continue to work for some time. For receptacles, it depends wholly on how often an attachment plug is inserted. The contact wipers become weak, which is where the hazard is created. I do know that the inspector in my neck of the woods that inspects rental property uses a receptacle tension tester on most of the recs to determine their state of wear. I think Daniel Woodhead is the OEM for receptacle tension testers. I think they're relatively inexpensive.
Some switches that were in use from the late 50's through the 70's contained mercury. They were not a mechanical switch inside. They have a blob of mercury inside that is sloshed this way and that as the switch handle is toggled. These mercury swiches have a definate distinctive feel when operated, as they don't "click", no matter how slight. They have a very smooth operation from the 'off' to the 'on' position. These switches last indefinately, unless damaged by an outside force. Because they contain mercury, they can present a hazard to the occupant if damaged such that the mercury is no longer contained. They are a disposal issue when replaced.
Same was in the 1965 NEC as well Marc....in regards to the rubber coated wiring
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I like to replace swiches and receptacles after 637 novemdecillion electrons have passed though the unit. Counting the little buggers can be quite tedius
DANG....and I figured I was the only one with a "novemdecillion" electron counter.....until I figured out I was counting the same electrons..OVER...and OVER and OVER again...
YEP....but the POCO loves it.....
I love when people say...they want to get off the GRID so they can be GREEN.....I say....you want to SAVE green.....you can't beat the theory of recycling any more than with Electicity......from your xfmr to the panel...we have been using those same electrons ...over and over again. Now that is what I call recycle at it's BEST Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I tell them...if you want off grid get a generator...lol.......and buy FOSSIL fuel to feel GREEN....
I consulted on a Wind Turbin project being presented in WVA.....not me fella I will stick to ON THE GRID work... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Speaking of green, how do you resolve the fact that my (nurse) wife gets SPAM email from the Vegan Society?
| Download the videos here all about physics and electricity | jtedesco1 | Electrical Inspections | 5 | 9/14/08 4:58 PM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 293 | 2/10/08 2:20 AM |
| Equipment Life Expectancy Chart | ekartal6 | Miscellaneous Discussion for Inspectors | 2 | 10/31/06 10:39 AM |
