Old 4/6/06, 2:28 AM
Default lighting up the neutral bus bar
Any suggestions as to why these wires go from the breaker to the neutral bus bar?
Thanks, Kent
Old 4/6/06, 3:20 AM
rmoore's Avatar
rmoore rmoore is offline
Please Note: rmoore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: lighting up the neutral bus bar
Kent,
They are either GFCI or AFCI breakers (can't tell from the photo). In either case the breakers require a neutral in order to function. They are normally "curly pigtails" as in your photo. They look fine.
Old 4/6/06, 3:22 AM
GFCIs and AFCIs actually have to pass both sides through the breaker so you need to complete the neutral path.
Old 4/6/06, 8:26 AM
David P. Valley's Avatar
Attachment 2686
THE "GROUNDING "TRUTH- Article To Read pabernathy Electrical Inspections 1 1/1/07 2:14 PM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 3:40 PM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 11:19 AM
