If I throw the breaker before leaving my cottage, will that protect the components on that circuit from lightning strikes?
| Find an InterNACHI certified Iowa Home Inspector (and anywhere else in North America) |
In short ( sorry for the pun ), If lighting happen to strike your system what would make it choose to only travel through the conductor on the breaker. If it did happen lets hope your system is grounded to a proper grounding electrode conductor so it can minimize the chances of a fire from latteral arching.
Now a power surge would be a different story. Either way if someone wants to protect their house to the best they can I would suggest they install an SPD and also one locally at computers, expensive TV's and so on as well. Two stages of protection is the best line of protection. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I saw damage caused by lightning which hit a roof mounted antenna and it was not pretty...even the water pump motor at bottom of the deep well was fried! It your cottage is situated on high ground, you may want to consider installing lightning rods. As Jeffrey said: *All lightning strikes are different, but typically it is about 100,000,000V.* And that is a lot of energy! Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
It would also help to disconnect telephone and CATV. Licensed Electrical Contractor Master Electrician BS Electrical Engineering Certified Master Inspector BestInspectors.Net License Prep and Continuing Education Home and Commercial Building Inspection - Electrical Plumbing - HVAC- Hydronics - Refrigeration - Fire Alarm Fire and Explosion Investigation - Commercial Sign Installation - Real Estate (Agent and Broker) - Appraisal Inspection Report Software for Windows - iOS - Mac - Android - Linux est. 1992
The gap between open breaker contacts is pretty small - adequate for interrupting up to the breaker's voltage rating. However, depending on how close the lightning strike is, the voltage applied to the breaker could be significantly larger than its rating and will easily jump the gap (among other nasty things it may do). The bottom line is that you really can't tell about lightning damage potential. Unplugging applicances is the most secure option, but even that is no guarantee.
If you are in an area with a lot of lightning or near a body of water, install a 2nd copper ground rod and put it at least six feet from your foundation.
If you unplug a tv you must also remove the cable. Don't forget to unplug your garage door opener. I never do any of that, but I have a long underground feed that helps dissipate spikes. I turn off my well breaker in case of a leak but don't bleed the pressure off when gone overnight. I used to live on a lake, neighbor said lighting hit the water in the cove about 500 feet away. It took out the EPROM in my hot tub control panel from a strong magnetic burst. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Thanks guys
Again....if you wish to truly be protected the best technology can do right now. consider installing a SPD Type 2 and 3 device(s) on your dwelling and ensure your grounding electrode system is complete.
| Lightning hit house | Jerry Maxwell | Electrical Inspections | 6 | 5/8/07 3:15 AM |
| Lightning Protection Systems- Do You Check It? | pabernathy | Electrical Inspections | 20 | 12/29/06 10:38 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
| Need help with lightning rods | sspradling | Electrical Inspections | 17 | 3/23/06 10:11 PM |
