I went to Home Depot and Lowe's today to buy these items just so I can have the manufactures directions on how to install them. I see many of them wired directly to the main lugs. I do not think that is proper. Can anyone direct me to the place where I can find the wiring directions to these items. I used search engines and could not find the wiring diagram or instructions. Thanks in advance for the help.
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
Delta lightning arrestors...
http://www.deltala.com/installa.htm Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
From what I can see surge protectors cannot be attached to the main lugs and the lighting arrestor is to be attached to the main lugs.
I guess I will have to look up on a case by case basis. Thanks for the info, it was very kind of you. Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
This section, from the 2008 NEC, would prohibit double tapping the mains in most cases since those lugs are typically rated for only one conductor.
It used to be common around here that the arrestor was attached to the lugs on the main disconnect. In all new installations they are now connecting them to a circuit breaker.
Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
I ran across this yesterday. Sorry the writing on the device is not very legible. I can't imagine this thing even working. A plastic device on the outside of the service panel with 3 conductors tapped directly to a 200 amp main breaker. Are you kidding me? Please tell me why I should be convinced this works.
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
This does NOT address you question but around here, the local power company will install these devices on your home to provide those protections for $4.95 a month. The other good thing is they will then put you into their system for the lowest rates...all the time. It will installed correctly and you get off the highest rates and into a lower cost per kilowatt rate. I would surprised they did not have something like that across the State as energy conscience as FL is. They will also do a FREE energy audit, install a new thermostat and some other energy saving features. They do all kinds of wacky things here....buy any old refrigerators, freezers to keep them out of the land fills, will pay for a new water heater if you currently have gas and will convert over....to name a few. There may be a similar program in your area.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
