What is with this outlet? A new constructed condo, all GFCI outlets had the green light on, showing it has been reset. On this one in the kitchen, it had both green and red lights on...??? On the faceplate, it says, "FOLLOW INSTRUCTIONS".
| Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America) |
Did you use your tester on both? (three light or sure test)
and I assume you reset. |
Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you have both green and red light that useally tell you have serious issue with wiring along downstream on the circuit.
Which brand name it is ? Both Pass and Seymour also Levetion both have slighty diffrent indentify what the codes are. However did you hit the test button on that receptale ? IF that is a Hubbel GFCI Repectale if red light is on that mean you lost the GFCI protection and that should be done by Electrician to address that issue and they can able find the fault on that one. Merci,Marc |
Yes, tested with my tester, and used the "TEST" button on the outlet as well. It seems to work fine, just has that red light on...
I could be wrong. First time I have seen it, but I recall from somewhere that one light is a power is on and the other is the safety light. If the power light remains on and the safety light is off, it is warning you that the outlet is not GF protected.
Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
Ground Fault Indicator When Red Steady ONInterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Help GFCI Tester Showing All Lights | kmccullough | Electrical Inspections | 8 | 4/19/08 1:11 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 8:33 PM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 12:29 PM |
| Lights & GFCI Outlets | thejnicki | Electrical Inspections | 14 | 2/28/07 3:48 PM |
