Old 10/26/07, 4:30 PM
John H. Cooper John H. Cooper is offline
Default Lightswitch In Tub Area
Gentlemen,
Today I found this dimmer control for the lights over a whirlpool tub. The dimmer is over the horizontal surface of the tile, but not directly over the tub itself. It is the right-most of the three coverplates in the picture, and is OBVIOUSLY put in that position to be reached from within the tub. The light switches for the rest of the bathroom are on the other wall, and don't control these lights. It is NOT protected by the GFCI serving the bathroom. I think it is dangerous. What do you think? At a MINIMUM, I think they should wire it to the GFCI protected outlet that is less than eighteen inches away. The third coverplate in between the two is for cable-tv and a phone.
Old 10/26/07, 4:57 PM
Unmoderated Guest
Default Re: Lightswitch In Tub Area
It's not over the tub so it's legal. Safe is a judgement call.
IMO it is not unsafe if it is wired properly.
Old 10/26/07, 5:52 PM
David P. Valley's Avatar
Yep, looks good to me.
"Click To Enlarge"
Old 10/26/07, 6:05 PM
Michael Larson's Avatar
Does this look like the AHJ had it removed? Why was it wrong?
Old 10/26/07, 6:09 PM
It's inside the tub area. It should be located outside the tub area.
Old 10/26/07, 6:17 PM
Still think so?
Old 10/26/07, 6:44 PM
Still think so?
Well, I wasn't on-site, but if you draw a line straight down from the outlet, it's inside the tub area.
Look for yourself...
"Click To Enlarge"
Old 10/26/07, 7:03 PM
"Click To Enlarge"
Attachment 15569
David, I agree with you but seems a gray area in the (word we don't use). The location in my pic is just as accessible as the one in John's original post.
Let me through in another question for thought:
How far would the wall behind the actual tub foot print in my pic have to be before the switch location became a non issue?
Old 10/26/07, 7:05 PM
Hmm. I have to admit, the drawing is straightforward. Still, the switch is over the tile, which is part of the tub structure. The drawing shows the switch over the floor.
I guess I am stuck on the intent. If you need to install a fan/light, which is in the ceiling, on a GFCI protected circuit (per the manufacturer's instructions) why would you not need to install a 120v light switch, that was clearly installed so that the occupants of the tub can reach it, with GFCI protection at least?
Old 10/26/07, 8:37 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Originally Posted by jcooper2
Gentlemen,
Is that a fridge?? First I've seen that set-up in a bathroom (coffee maker and fridge)
Old 10/26/07, 10:19 PM
Yeah Brian, That is a fridge. It kinds of reminds me a a hotel room.
You know, stepping back a minute. There really isn't that much different here than in the kitchen or bathroom where you have your hands under the water, or holding the sprayer, and reach up to turn on the light or the garbage disposer. The current, were your hands to be wet and somehow the water got to the conductor, would run down one arm, through the heart, and out the other. You would be just as dead, or at least severely hurt, as if you reached up to that switch from the tub.
Only you wouldn't be floating around in your all in all when they found you...
Old 10/27/07, 7:08 AM
If the Electrician simply installed this switch 4 to 5 inches to the right, like this..
then it would have been all set.
Old 10/27/07, 7:12 AM
Barry Adair's Avatar
In John's original picture (butt ugly bathroom, imo) or Michael's I can't see a non-destructive access panel to inspect the pump motor bonding and possibly GFCI receptacle for the hydro-tub.
I call access absence all the time as well as depicted switches.
"although the hydro-tub switch location may pass past or current AHJ building standards, I advise removal and coverplate installation too avoid the potential for electrocution."
I don't need anything but common sense to report what I find and will leave the fighting to the homeowners, builders...
The rest would be up to the consumer to choose their fate.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/27/07, 7:22 AM
You are absolutely correct Barry and it was reported as such but that wasn't the point of the thread
When I first observed this I thought maybe acesss was through the vanity sidewall but none there either. Why the AHJs approve this type on installation is beyond me.
I still would like to see the professional opinion of some of our sparkies on the light switchbox placement. I think the NEC is a bit unclear on this issue and the diagrams I've seen never seem to show this type of situation. I guess that leaves it up to the AHJs and us poor HIs.
Old 10/27/07, 7:31 AM
Got it, but in my pea-brain if I can't verify the "other" required electrical installation features it helps to better drive my points across to my clients that the entire hydro-tub installation may be incorrect. thus they may be more apt to remove and cover as in your photo.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Chicago Area Homebuilder Files for Bankruptcy ldapkus Miscellaneous Discussion for Inspectors 1 10/23/07 9:26 AM
Bay Area Prices Looking Up! whandley Miscellaneous Discussion for Inspectors 0 4/26/07 11:29 AM
Phoenix area Chapter Meeting - Jan 24th cvowell General Inspection Discussion 0 1/11/06 5:00 PM
