Old 4/1/06, 9:59 PM
gporter's Avatar
gporter gporter is offline
Default Linemans gloves
How many of you wear lineman's gloves while inspecting a panel?
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 4/1/06, 10:01 PM
ekartal5 ekartal5 is offline
Please Note: ekartal5 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Linemans gloves
Just thinking about getting a pair last night. Recommendations anybody?
Old 4/1/06, 10:37 PM
pdacey's Avatar
pdacey pdacey is offline
Please Note: pdacey is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would, but I don't think I'll ever have to block a noseguard while doing an inspection.
Old 4/1/06, 11:09 PM
Roy D. Cooke, Sr's Avatar
Not me
Roy sr
Old 4/1/06, 11:43 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
I wear a pair of calfskin work gloves.
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 4/1/06, 11:45 PM
Richard L. Bennett Richard L. Bennett is offline
It is cheaper to buy something that is a dielectric to stand on that a set of gloves
rlb
Old 4/2/06, 5:11 AM
Russel Ray's Avatar
Gloves?
It was 83°F at my place yesterday.
I moved to San Diego so I wouldn't have to put up with all the Northers in Texas that the folks in the Great White North kept sending us each week.
Gloves?
Ha.
Not on your life.
Old 4/4/06, 1:55 PM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
There are different ratings for 'linemans gloves'. The lowest being 1000v. The rubber is much thinner than higher voltage gloves so they're easier to work with, but the rubber (which gives the gloves there dielectric strength, needs to be protected when stored and when used. When using, a lineman will wear a pair of leather gloves (gaunlets)on top. We use to have to exchange our low voltage and our high voltage gloves for a newly tested pair every six months in my past work as a lineman.
The kind of work home inspectors do, in my opinion doesn't warrant the use of gloves. Trust me, you'll hate wearing them. Tool usage is very hard to get use to and when removing a cover you're much more likely to have an accident (dropping the cover into the panel and creating a nice arc blast, for instance) when wearing gloves. Why would you consider wearing gloves? Are you working in the panel? For just removing the cover and looking inside I don't know how a pair of 1000 volt gloves could do anything but hinder. If you're nervous about the cover being electrified check it with a volt pen first, but be aware of your pens sensitivity to static and just a nearby wire.
In my opinion it would be very hard to electrocuted when removing a 120/240 volt panel cover if you're wearing a good pair of boots and not in contact with any other path to ground. Let's say even if there was a hot wire touching the inside of the cover and you didn't test it first, you could touch that panel cover with both hands without even knowing it was hot. It isn't until you provide a path to ground that you get current flow (hand to foot if not wearing a good pair of boots, or hand to hand if your other hand is touching something that provides a path) You're much more likely to have an eye injury from arc blast when removing a cover and inspecting a panel so wear safety glasses and you'll be fine.
Old 4/6/06, 12:32 AM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
good point james. i'm training a new guy and was deminstaiting this to him. i was changing a wired smoke detector while hot (save it safety guys ), and i held onto the hot while he cringed in disbelief that i wasn't getting zapped. then i explained it much the way you did. i also explained that getting zapped by the hot to ground or neutral is different than if you grab both wires from a light switch (just pulling the load of the light). i still don't think he gets it. so i told him "you'll know if you get bit, your elbos and balls will tingle". well mine do anyway.
Old 4/6/06, 12:48 AM
James
Thank you for your post. The laws of physics do not change -- Voltage rated gloves not required....
Watch your shoes and what you are standing on --- If it is wet - don't
Yes, eye protection -- and that should be on the head all through the whole inspection esp in the crawl spaces and the attic
rlb
Old 4/6/06, 2:42 AM
Russel Ray's Avatar
Well.
I believe I'm off to try something new.
Darn margaritas.
Old 4/6/06, 10:57 PM
Jay Moge's Avatar
Originally Posted by rray
Well.
Darn margaritas.
Thats funny RR. i like elbows too.
Old 4/6/06, 11:10 PM
Ted Allen Ted Allen is offline
I were 00 gloves( are rated at 500V) with a calf skin leather glove. I always check with my "tick " tester first.
Anyone who says this is a hinderence is nuts!
All we do is pull the interior cover and look at the panel. I do not think that pulling the interior cover of an electrical panel is all that dangerous, but....
Always were your safety glasses and always were some gloves!! Some nice boots also help.
JMO
It's true that you may grab a "hot" wire at 13,800 volts and not be shocked, but if you make the smallest mistake...... You are toast!!
Do me a favore and were your PPE.
Old 4/6/06, 11:18 PM
Here is the problem with PPE
Cost
Maintenance
True need
Remember that Joe home owner should be able to turn on breakers on the master breaker box that have been turned off
These are just like a wall switch
rlb
Old 4/6/06, 11:37 PM
Cost
Maintenance
True need
rlb
True, but how many Home Owners open the interior cover?
It is only my oppinion and what I do to stay safe. To each his own.
