| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
I have a little problem swallowing this here how about you guys
Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. Last edited by cbottger; 5/13/08 at 11:10 PM.. |
Can't really make out the first picture of the neutral that well, but it appears to be uninsulated. Is that the case? If it is I have a story about my first encounter with a bare neutral in a service entrance!! |
I can't see the issue with the mast or the panel bottom. Can you lead us a little closer?
I did miss the doubled neutral and ground. Here there would be a lug installed to bond the mast to the neutral in the triplex. It is hard to tell that the neutral in the mast is uninsulated from the pic. Last edited by Jim Port; 1/12/08 at 1:41 PM.. |
If that's a bare neutral in the mast then wow! If it's not bare then it looks kind of small.
Also, no mast insulator for the drop to attach to. I am surprised the POCO hooked this up. The second pic I don't know. |
This was on a 3k+ home with a 100 amp FP Stab-lok the buss bars indicated excessive heat blew me away first time to ever see this. Yes sparky will be visiting this home after my report. I have no idea why the electric company ever connected to this in the first place. Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. |
Looks like the wires show signs of burned insulation, and the two neutral and one/one or 2 EGC and Neutral under the termination are all incorrect there can be no dispute here!
There is a missing screw as well. Last edited by jtedesco1; 1/22/08 at 8:12 AM.. |
Between this post and all the other threads you are bringing to the top looking for adoration this topic is getting quite worn out. It seems like one huge pissing patch that you are trying to win through overwhelming the boards with posts. Can you say beating a dead horse? |
We have quite a few older installations here where the neutral is a solid bare #4 or #2 up thru the mast and out the weatherhead. These were obviously inspected and passed at one time, and have been in service for many years.
Petey, what sort of hazard would exist with a bare neutral in the pipe? I realize we don't do it this way anymore, but I am curious if this is a hazard or not. |
The neutral is pretty much always carrying <some> current. Any compromise in this conductor could cause anything it touches to become live.
6-308 Use of bare neutral in consumer's service The neutral conductor of a consumer's service shall be permitted to be bare if this conductor is (a) made of copper and is run in a raceway How about down there? If the #8 AWG copper conductor is large enough to carry the unbalanced load, it may* meet code here!! *may- part of this conductor is outside the raceway (mast conduit) and may not be correct. Will have to have to call AHJ on Monday. The first bare service neutral I found (new house; 2 years ago) only ran from the meter box to the distribution panel and was fully contained in a raceway. Rest of story and my reasoning/persistance later. Last edited by Brian A. MacNeish; 1/12/08 at 1:18 PM.. |
The only question I asked was do you reaize you are beating a dead horse. So you conveniently give an answer a question that was NOT asked.
Typical. |
I chose to avoid the vulgarities and will remain as professional as I can be, your attitude is not necessary. My panelboard was installed since 1981, that was and still is the issue and the still shows one wire per neutral terminal printed on the cabinet front.
Nice try though with the vulgarities comment. |
