Old 9/18/07, 11:19 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default load cliiper?
came across a loudly buzzing "load clipper" as was stated on the label. 2 circuits inside...1 attached to heat pump and the other to stove. 1 of the circuits looked like it was burned (electrically). Label said 30 amp max, circuit "must open" at 15 amps. I guess this is some sort of pre-historic gfci? Recommended an electrician take a look since the circuit was burned and was buzzing pretty good. insight?
Old 9/19/07, 12:36 AM
Brian E. Kelly's Avatar
Default Re: load cliiper?
http://www.nachi.org/forum/showthread.php?t=18361
Old 9/19/07, 1:31 AM
Brian,
Is that a members only section? When I clicked on it, the box that says I don't have priviledges popped up.
Old 9/19/07, 1:39 AM
Sorry Scott. Electrical load controller, turns off one piece of equipment when power use goes up. Popular in the 1970's after the energy crisis. I always defer them.
Old 9/19/07, 12:01 PM
A "buzzing"sound coming from an enclosure containing a relay usually signifies a relay armature that is not closing completely due to things like rust, sticking mechanism, movement blocked by insect activity, etc. The result can be a burned load contact and eventually failure to compelte th circuit. No matter - the relay probably should be replaced.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 4:05 PM
Voltage Drop dmacy Electrical Inspections 51 9/7/07 10:57 AM
Load Side Panel Steven Brewster Electrical Inspections 18 5/7/06 8:40 AM
