Ground-fault circuit interrupters Accessory buildings, dwelling units, 210.8(A)(2) Aircraft hangars, 513.12 Appliances Drinking fountains, 422.51 High-pressure spray washers, 422.49 Vending machines, 422.51 Basements, dwelling units, unfinished, 210.8(A)(5) Bathtubs, hydromassage, 680.71 Carnivals, circuses, fairs, and similar events, 525.23 Definition, Art. 100–I Electrically operated pool covers, 680.27(B)(2) Electric signs, portable or mobile, 600.10(C)(2) Electrified truck parking space supply equipment, 626.24(D) Elevators, dumbwaiters, escalators, moving walks, platform lifts, and stairway chairlifts, 620.85 Fixed electric space-heating equipment cables, 424.44(G) Fountains, 680.51(A) Garages, commercial, 511.12 Garages, dwelling units, 210.8(A)(2) Generators, portable, 445.20 Naturally and artificially made bodies of water, electrical equipment for, 682.15 Permitted uses, 210.8, 215.9 Personnel, protection for, 426.32 Pipeline heating, 427.27 Pools and tubs for therapeutic use, 680.62(A), 680.62(E) Receptacles, 210.8 Bathrooms, in dwelling units, 210.8(A)(1) Bathrooms in other than dwelling units, 210.8(B)(1) Boathouses, 555.19(B)(1) Construction sites, at, 590.6 Fountains, 680.57(B), 680.58 Garages, in dwelling units, 210.8(A)(2) Health care facilities, 517.20(A), 517.21 Kitchens in dwelling units, 210.8(A)(6) Marinas and boatyards, 555.19(B)(1) Mobile homes, 550.13(B), 550.32(E) Outdoors, dwelling units, 210.8(A)(3) Park trailers, 552.41(C) Pools, 680.5, 680.6, 680.22(A)(4), 680.22(B), 680.32, 680.62(E) Recreational vehicles, 551.40(C), 551.41(C) Replacement, 406.3(D)(2) Required, 210.8 Rooftops in other than dwelling units, 210.8(B) Sensitive electronic equipment, 647.7(A) Spas and hot tubs, 680.43(A), 680.44 Wet bar sinks, 210.8(A)(7) Swimming pools, see Swimming pools, fountains, and similar installations Split Second Safety GFCI Code Proposal Development for the 2011 NEC The NEC is revised every 3 years. What are some of your ideas for any changes? Any new ideas for your proposals for the 2011 NEC must be done at this proposal stage and sent in before 11/7/08. Otherwise, you’ll have to wait for the 2014 NEC! Here's a new Power Point file developed by the IAEI: www.IAEI.org 1. Developing good proposals 2. Online proposals are also permitted by NFPA. Last edited by jtedesco1; 5/6/08 at 7:14 AM.. Reason: add video and links |
Do you have the dates each of those went into effect?
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Reviewing the NEC editions from 1968 on, and searching the index will have that information, Very good question.
I sold most of my old NEC's to Jerry Peck, but maybe the NFPA Library 617-770-3000 can help with that information. I will bet Mike knows, or will give this assignement to his students, I hope. |
I have a list that I believe came from that book, but it isn't up to date and as inclusive as the locations that Joe posted.
That list could be updated so we can be sure of the dates, again the index in each code can be a good place for us to start. Here's another option: 215.9 Ground-Fault Circuit-Interrupter Protection for Personnel. Feeders supplying 15- and 20-ampere receptacle branch circuits shall be permitted to be protected by a ground-fault circuit interrupter in lieu of the provisions for such interrupters as specified in 210.8 and 590.6(A). |
Bruce Erny is a non-member guest and is in no way affiliated with InterNACHI or its members.
[quote=Marc D. Shunk]I know that the book that many home inspectors have "Electrical Inspection of Existing Dwellings" has a chart in it with all those dates. I think that book might be out of print now. It was pretty expensive, as I remember.[/quot
Here is an easy to follow version. http://www.mikeholt.com/documents/ne...ment_page2.pdf |
cutting through the chatter.
When if at all does GFCI need to be on an counter Island .I thought only with in 6 feet. Some one said they all need it. Refering to near a kitchen though it should not matter . |
For a few code cycles now in a residence it has been ALL receptacles serving kitchen counters. The "six foot rule" as been gone for a while.
General use wall receptacles do not require GFI protection. |
Ok... serving kitchen counters
What constitutes a kitchen counter since an Island is far away from water? |
I agree. I have done kitchens with isolated sections of counter that were on opposite walls from the sink and totally removed.
GFI's made NO sense whatsoever, but were required. I don't think there is any denying that an island counter is still a counter though. |
Ok ....
I always figure part of a continuous counter, but will make note. |
The 210.08(A)(6) rule about GFCIs just says "countertops", there is no reference to sinks or water. They specifically address peninsulas and islands.
Basically if you are barefoot on a ceramic tile floor you might as well be ankle deep in water. Last edited by Greg Fretwell; 5/4/08 at 11:36 PM.. |
it's simpler than that, if the outlet services a horizontal surface in or adjacent to the kitchen it needs to be GFCI. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 10:06 AM |
