Here's a panel from two days ago.
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
rgrizzle is a non-member guest and is in no way affiliated with InterNACHI or its members.
I bet it was feeding this
Mark, what was the switch for? Maybe there was overcurrent protection upstream?
The switch is the main, then they had conduit running to a shed and conduit going to the sub panel in the house.
That looks like what i have seen a lot of in certain areas out here. Open up a meter box remove the meter and jump the to feeds and wow now you dont have much of a bill. I have seen guys even run a connection to the meter they disconnected and create a small current so ComEd doesn't get wise. the amazing thing is I have known guys that install those with the line hot and minimal gloves.
That's what the wasp nest are for. If they get to hot they'll zap it.
| Oversized Edison Base Plug Fuses | jtedesco1 | Electrical Inspections | 2 | 12/21/07 1:08 PM |
| A/C electrical disconnect fuses | bmargiotti | Electrical Inspections | 43 | 12/3/07 11:08 PM |
| Is There Anything to Report Here? | pdickerson | Electrical Inspections | 9 | 10/29/07 8:44 AM |
| Help with cartridge fuses please | bracine | Electrical Inspections | 14 | 3/6/07 8:14 AM |
| Old -OLD Fuses | rroeske | Electrical Inspections | 3 | 4/27/06 2:06 PM |
