When you report on loose recepts, (you know, when they are loose in the wall from normal use not falling out) does this comment go to the summary as something that should be repaired or just an FYI?
Thanks, Buckeye Home Inspections Shane Boyd CMIA, CEE BuckeyeHI@yahoo.com www.buckeyehi.com Myrtle Beach, SC "To be successful, suround yourself with successful people"
Shane,
I report they need to be repaired (tightened) and that automatically goes into the summary. The fact the receptacle is loose can cause the wires to become loose or come apart, especially the ones which are wired (back-stabbed) fashion. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Do you report maintenance issues in your report summary? Such as: clogged furnace filters rain gutters with debris non working lights foundation plantings to overgrown paint defects I know some of these are rather subjective. I generally report on defects that materially affect the value of the property in addition to any safety related issues. These become part of the report summary. Others may hold differing opinions on this. |
I was not referring to the blades being. That I feel should just be replaced. I meant just plain loose in the wall.
What I am getting towards here is, I am using Homeguage, and a lot of my summaries are 4+ pages. When you read them, they seam small. Clogged furnace filters, loose recepts, loose countertops, whatever. Just wanted to see what you all put in the summary, so I started here. But Dale, you answered my ? Thanks Buckeye Home Inspections Shane Boyd CMIA, CEE BuckeyeHI@yahoo.com www.buckeyehi.com Myrtle Beach, SC "To be successful, suround yourself with successful people"
Clogged gutters that can't drain water are just asking for problems with open rafter tail rot. I see it all the time. We don't have a real winter here in California, just a lot of rain. |
LJ Ross is a non-member guest and is in no way affiliated with InterNACHI or its members.
are these dangerous
Are |
I put it in the summary as a clogged filter is putting undue strain on the system. I have a blanket statement about replacing filters in the report. |
BTW have your seen the washable type? |
Sorry to hear you are shocked Michael. We are required by the State to report on the condition of the filter here in all of our reports. (items 62 & 68] So when I find dirty filters I call them out. Ask some of the HVAC guys here what happens to the efficiency HVAC systems with dirty filters? Last edited by bkelly2; 10/15/06 at 1:37 AM.. |
I don't think what State you are from makes to much difference to me.
Loose receptacles or wore out blade slots, are all a hazard in my book for a family occupied home. They go in the summary report as a safety hazard and is usually hi-lighted so it can't be missed while reading the report. As far a a clogged air filter, if it is clogged, unmaintained, or unwashed as one would say, it is impairing with the proper function of the heating or cooling unit. I write it up as such. You can relate a filter to the one on your car, if it is so dirty, your car will not function. Reminds me of a joke where the brain said to the rest of the Body, he was the Boss. The anatomy part of the body that filters, said he was. The Brain kept insisting he was the Boss so the other anatomy part said OK, and stopped functioning. After two days went by, the Brain was so messed up that no straight thinking would work, and gave up. He said OK, your the Boss. ha. ha. Marcel </IMG></IMG></IMG> |
Plugs defiantly need Repair or replacing Roy Cooke </IMG> Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Exterior GFCI receptacles | lfreeze | Electrical Inspections | 11 | 1/14/07 6:30 PM |
| open ground on 3 garage receptacles | dnasser | Electrical Inspections | 14 | 10/30/06 5:53 PM |
| Loose tape and loose popcorn texture | cdewitt | Interior Inspections | 6 | 6/9/06 5:14 PM |
| Receptacles Mounted on Covers | jtedesco1 | Electrical Inspections | 1 | 2/5/06 12:13 PM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 9:29 PM |
