Old 1/3/11, 12:27 AM
Stephen P. Shockley's Avatar
Stephen P. Shockley Stephen P. Shockley is offline
Default Loose wires in electrical panel
I noticed the two loose wires at the bottom of the electrical panel. I also noticed that the wiring to the water heater was replaced with an orange insulated wire when the replacement water heater was installed in 2003. I'm guessing those two loose wires originally went to the water heater. I'm not clear on what to say about these two loose wires in my report that aren't being used. Any suggestions would be appreciated.
Thanks,
Steve
loose-wires-electrical-panel-bennetts-123010-232.jpg   loose-wires-electrical-panel-bennetts-123010-227.jpg
Shore-Footed Property Services, LLC
Stephen P. Shockley
MD Licensed Home Inspector
410-726-3471
Salisbury, Md
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/3/11, 4:57 AM
zswieca zswieca is offline
Please Note: zswieca is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Loose wires in electrical panel
Improperly terminated wires noted at the --- panel. The ends of spliced wires should be covered with a wire nut and electrical tape should be wrapped over the nut and onto the wires. Note, the inspector does not pull or track the source of terminated wires.
Old 1/3/11, 5:05 AM
Robert Meier's Avatar
I agree they would be safer if the ends were either taped or a wire nut were installed. This would keep inadvertent contact with the live buss from energizing the other end of the cable or worse causing some arcing which may lead to other problems. According to the NEC abandoned line voltage cables and conductors can remain for possible future use. Abandoned CATV and data/phone wiring must be removed or tagged for future use. No such requirement exist for line voltage cables.
ARTICLE 800 Communications Circuits
I. General
800.25 Abandoned Cables.
The accessible portion of abandoned communications cables shall be removed. Where cables are identified for future use with a tag, the tag shall be of sufficient durability to withstand the environment involved
Old 1/3/11, 6:26 AM
Banned
Thanks,
Steve
"Abandoned line voltage cable found in electrical panel. It can be removed or, if left in place, bare copper conductor ends should be covered
by wire nuts or electrical tape. Consult licensed electrician"
Old 1/3/11, 8:56 PM
Wow, great comments. I was about to only suggest removing the loose wires. Thanks gentlemen.
Regards,
Steve
Stephen P. Shockley
410-726-3471
Salisbury, Md
Old 1/3/11, 8:58 PM
Regards,
Steve
Brian summed it up nicely.
Old 1/4/11, 5:41 PM
Kenneth Greene's Avatar
Kenneth Greene Kenneth Greene is offline
it looks like from the photo that the orange wire come through exterior of the house wall then travels up into an exterior mounted breaker panel. shouldn't that cable be protected from cutting in conduit?
Hudson-Mohawk Inspections LLC
Ken Greene
NYS license 16000041691
IAC2 Cert. # IAC2-01-6345
NY State Pest Technician: T5865955
www.hudsonmohawkinspections.com
Old 1/4/11, 7:36 PM
Jim Port Jim Port is offline
Unmoderated Guest
No, the problem is that that type of cable is not listed for use outdoors.
Conduit would only be required if it was deemed that the cable was subject to physical damage.
Old 1/4/11, 8:32 PM
Christopher Currins's Avatar
Isn't the orange cable (10ga) ) subject to physical damage?
Christopher Currins
Certified, Licensed
Old 1/4/11, 8:36 PM
Michael Larson's Avatar
That misses the point Chris.
The cable is not out door rated. It it was UF there would be no problem.
Michael Larson
Hudson, WI
Old 1/4/11, 8:45 PM
Unmoderated Guest
Physical damage is a very subjective term and is not defined in the NEC. What you may consider may vary widely from what someone else considers subject to damage.
Old 1/4/11, 9:07 PM
So, in this installation, other than not being UF, you would not consider it a safety defect?
Christopher Currins
Certified, Licensed
Old 1/4/11, 9:13 PM
UF or NM I would consider an exposed cable installed as in that photo subject to physical damage. Now use UF and properly support it then it might be OK. SE cable is run out of the bottom of a meter pan exposed everywhere around here.
Old 1/4/11, 9:17 PM
Thanks. Same here with SE cable in rural areas.
Christopher Currins
Certified, Licensed
Old 1/4/11, 9:20 PM
As Jim stated it's not defined by the NEC so subject to physical damage is open to interpretation. I used the SE cable as an example because in many area (including this one) that's an acceptable wiring method in an exposed location. Run it in a driveway and then you would have a problem.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Main panel...recommendation ? dnasser Electrical Inspections 6 11/22/09 9:55 PM
4 ground wires into 1 in main panel psiposs Electrical Inspections 13 5/18/06 1:27 PM
