Newer installed main panel had 3 60 amp breakers and then the bottom legs fed the original 200 amp panel in the basement. Is this acceptable or not. I would think that the addition would cause the original main to become a sub.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The panel in the basement would be considered a sub panel since it's after the service disconnect. What size conductors feed the subpanel?
Are there two green conductors under one lug at the top? |
No the two green were the grounds. One beaker was for the compressor the other two for heat strips. The house was only 200o sf and had a 5 ton heat pump. I will just wirte it up as such. Thanks Robert.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net Last edited by sfogarty; 7/15/11 at 7:18 PM.. |
Why in the heck would a 200 sq foot house need a 200 amp feed or a 5 ton HVAC?
2000 sf that was a type o The 5 ton is another story
What is the size disconnect at "main" panel?
The original panel doesn't "become" anything. It's "use" has changed. It is no longer the service equipment, it is now a load-side (sub) panel. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
It was 200 amp also, which was another deal as well. The only conclusion I could come up with is the previous owner got a used heat pump and had a someone add the new panel with extra breakers for the upgrade.
Whats confusing is trying to figure out what the last clown chose to do. Always fun around here.
sub panel requires the neutrals to be insulated from the grounds and the panel should not be bonded
All panels are required to be bonded to the GES.
lol...now you know it was not 200 sq ft....lol...silly man !
Paul W. Abernathy |
It should indeed be bonded...just not to the grounded (neutral ) conductor at this remote distribution panel. It should be bonded to the equipment grounding conductor (EGC) provided (I Hope) within the feeder to this panel.
Paul W. Abernathy |
