Old 12/15/11, 7:43 AM
Dale Young's Avatar
Dale Young Dale Young is offline
Default Main breaker panel
Did an inspection the other day, Main breaker panel was full with at least 3 double taps with arching present on one of the double taps. I recommend addtional breaker box. She wanted to know if this was against code. I dont do code and will check on local codes but an looking for any other thoughts. Wasnt able to get my pics uploaded. Thanks
Dale Young
Young & Son Home Inspection Service
601-431-3551
www.younghomeinspection.com
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/15/11, 8:55 AM
Default Re: Main breaker panel
Sometimes you can replace one breaker with two-mini's, which are the same size as the one that is double-tapped. Document, inform, let the buyer decide. Stating solutions can cause grief.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Who is she? Arcing? Against code? Double taps? In all your years of inspecting homes, have you ever seen this? How did you report it?
Old 12/15/11, 9:28 AM
Dale Young's Avatar
She- Client; double tap where 10 gauge wiring; code- safety first!
Dale Young
601-431-3551
Old 12/15/11, 9:34 AM
David A. Andersen's Avatar
#10 ???
What did it go to?
The double tap can be taken care of inside the panel without adding breakers (sometimes).
You need an electrician out there, simple as that.
BPI# 5015804
Old 12/15/11, 9:43 AM
Dale Young's Avatar
Added whirlpool tub?
Dale Young
601-431-3551
Old 12/15/11, 9:44 AM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Any pictures of the panel in question?
Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas.
Old 12/15/11, 9:49 AM
Dale Young's Avatar
had problems w/ camera
Dale Young
601-431-3551
Old 12/15/11, 9:51 AM
Two #10 on what size breaker?
What was the other circuit for?
BPI# 5015804
Old 12/15/11, 9:54 AM
Dale Young's Avatar
unclear
Dale Young
601-431-3551
Old 12/15/11, 9:57 AM
did you have 2 #10 wires on one breaker?
One wire went to a tub, where did the other go?
What was the size and type breaker they were attached to?
BPI# 5015804
Old 12/15/11, 9:58 AM
I hear you, I keep an extra camera and batteries in my bag as it is very common for there to be a problem.
Old 12/15/11, 10:19 AM
Dale Young's Avatar
30 amp
Dale Young
601-431-3551
Old 12/15/11, 11:15 AM
Jeffrey R. Pope's Avatar
A "double-tapped" breaker is wrong - period. There are certain brand/types of breaker that will accept two conductors, and they are listed accordingly. So the answer to your code question is "yes," this is a code violation. Specifically, [paraphrased] (1) Terminals for multiple conductors must be listed and labeled, and (2) Manufacturers specifications must be adhered to.
An additional (sub) panel is not always necessary. As suggested, tandem (mini) breakers can be installed, breakers for multiple conductors can be installed or the double-tap can be "pigtailed" to a single conductor. However, the appropriate method should be determined by an electrician so that the breaker is not over loaded.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/15/11, 2:21 PM
Bob Elliott's Avatar
Here you would need to add a sub-panel.Minis not allowed.(or what Jeff said)
200 main breaker X 2 sfalvey Electrical Inspections 11 10/9/08 11:31 PM
Main and Sub Panel gheller Electrical Inspections 10 9/25/08 9:22 PM
Panel main rating sfalvey Electrical Inspections 7 9/24/06 8:46 PM
