Old 5/30/06, 2:10 PM
Christopher Rich Iii Christopher Rich Iii is offline
Default Main disconnect needed??
I did a 3yr old condo inspection this morning and the panel(Murray) did not have a main disconnect. Is this code? If so did it change in the last several years. There were more than six throws on the breakers which should require one. Any help would be appreciated!!
Thanks,
Chris
Old 5/30/06, 4:26 PM
Jeffrey R. Pope's Avatar
Default Re: Main disconnect needed??
The service disconnect is not usually located within individual condominiums. Typically, each unit has a distribution panel inside, with a service disconnect located in a common room or exterior closet.
The panel should have been wired as a distribution panel rather than service equipment. Do you have any pictures?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/30/06, 4:35 PM
It's probably a sub panel...did you determine that?
Old 5/30/06, 4:37 PM
Oh, I see Jeff took care of you while I was on the phone booking an inspection.
Old 5/30/06, 5:31 PM
I'm out of town on a "working vacation." I like days like today. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/30/06, 5:41 PM
I can see why!
You deserve it...enjoy!
Old 5/31/06, 10:37 AM
Yes, most of the time Condo's have an outside distribution center or it can also be located in a basement or electrical vault. Check to see as Jeff stated if this panel is simply a "Remote" distribution panel......check the # of wires as well......may have other issues beyond that as well.
Paul W. Abernathy
Old 5/31/06, 10:05 PM
Thanks, Paul, Jeff and Larry..
Chris
Main disconnect at meter instead of main panel. OK? kshepard Electrical Inspections 14 11/8/06 6:24 PM
Tenant access to main disconnect in apartment bldg? lhoffman Electrical Inspections 4 9/1/06 11:54 AM
Disconnect and Main panel srowe Electrical Inspections 10 6/13/06 7:49 PM
No main disconnect ecox1 Electrical Inspections 19 3/7/06 9:59 PM
Main Disconnect Manufactured Home dbreen Electrical Inspections 1 3/4/06 12:42 PM
