Old 1/30/11, 1:11 PM
SANTHOSH K. CHEMBAN SANTHOSH K. CHEMBAN is offline
Default Main Electrical Panel
Please help identify the type of Panel attached in the photo. Is this is type uses fuses? How does the disconnect work? What is the name of this type of Panels?
Thanks
Santhosh Chemban
Tristate Home Inspection
New York
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/30/11, 1:19 PM
Roy D. Cooke, Sr's Avatar
Default Re: Main Electrical Panel
Sorry I expect there could be pull fuses There .
I expect this is OLD and obsolete .
How old is the home does it have Knob and tube . More info would help establish the age ..
I see ITE when I blow the picture Up.
Old 1/30/11, 1:35 PM
The House is built in 1960. Wiring method is non-metallic wires. All branch circuits have regular breakers. Please see attached photos. Thanks
Old 1/30/11, 1:36 PM
Banned
Originally Posted by schemban View Post
Attachment 41700
Thanks
Santhosh Chemban
New York
By the instructions on the red label, looks like an early panel with some breakers being used. I have seen some mixed panels up here with breaker main disconnects and fuses as circuit protection.
I'm wondering if the main disconnect may actually be a fused pull-out similar to what we see in older fuse panels for electric dryers/stoves.
Old 1/30/11, 1:40 PM
Jeffrey R. Pope's Avatar
Walker Electric panel, with a fuse-block disconnect.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/30/11, 1:49 PM
Thank you all for your help. I am proud to be part of InterNACHI.
Old 1/30/11, 2:15 PM
David C. Macy's Avatar
Ah come on Jeff, you can not just read the label!!
Do not give Jonny Walker a ride cause Jack black is right by his side....
Sorry could not resist.
Old 1/30/11, 3:03 PM
Banned
You must have posted the extra info just seconds before my post.
Old 1/30/11, 5:03 PM
Originally Posted by dmacy View Post
Ah come on Jeff, you can not just read the label!!.
Sometimes, it's just that simple
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/30/11, 7:06 PM
Robert Meier's Avatar
I won't speak for the single and two pole CB's, but according to the label those twin CB's are a violation of the panel listing.
Coming to Schaumburg, Ill - Electrical Training with The Electrical Guru ksitzes Inspection Education & Training 12 3/17/10 4:19 PM
Evaluating your home's wiring system mcyr Electrical Inspections 0 12/30/09 1:31 PM
Distribution and Main panel jfrederick Electrical Inspections 5 5/4/09 6:53 PM
Some good questions that always need answers jtedesco1 Electrical Inspections 5 6/16/06 9:10 PM
