Old 11/8/11, 12:44 AM
William T. Misegades William T. Misegades is offline
Default Main panel and Sub panels
Today's house had the main panels/breaker and directly on the other side of the wall in the garage were the breaker panels. These breaker panels are sub panels (the neutral is separated from the ground and box and the ground is bonded to the panel.
Aren't these sub panels required to have a disconnect or do the exterior ones suffice?
main-panel-and-sub-panels-dsc02831b.jpg main-panel-and-sub-panels-dsc02867b.jpg
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/8/11, 4:45 AM
Robert Meier's Avatar
Default Re: Main panel and Sub panels
No disconnect is required for those sub panels. I don't see any grounding electrode conductors in the two service disconnects.
Old 11/8/11, 6:52 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Ground is bonded to the neutral because of electrical conduit.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/8/11, 11:06 AM
I was about to right it up as no grounding electrode. So, are you saying this installation is correct?
Will Misegades
TREC# 10465
Old 11/8/11, 11:14 AM
Jeffrey R. Pope's Avatar
There is no visible GEC, regardless of the equipment bonding.
The GES should be verified or established.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/8/11, 2:24 PM
Joseph M. Whitt Joseph M. Whitt is offline
Yes the remote panels are compliant. They do not need a main breaker for the panel as the service disconnect will turn the remote panel off.
As to the grounding electrode, it could be installed in the enclosure that is below the two service disconnects.
Mike Whitt
Contractor/Instructor
Old 11/8/11, 2:30 PM
KEVIN WOOD's Avatar
Correct and I also agree with Jeffrey P. If you cannot confirm the GEC don't guess.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
