Old 12/8/11, 2:24 PM
Sean Fogarty's Avatar
Default Main panel electrical problem
A wee bit toasty!!
main-panel-electrical-problem-pc080041.jpg   main-panel-electrical-problem-ir000498.jpg
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/8/11, 2:27 PM
Default Re: Main panel electrical problem
What was the load on it?
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 12/8/11, 2:55 PM
Jeff
The house was empty so the only real load was the heat pump running. The temp was not that significant then but once someone moved in I could only imagine. Either way it needs fixin!
865-256-5397
Old 12/8/11, 7:02 PM
Joshua L. Frederick Joshua L. Frederick is offline
Just caulk it
Old 12/8/11, 7:10 PM
Jeffrey R. Jonas's Avatar
You needed IR to find that? Getting lazy, old man!
Old 12/8/11, 7:13 PM
Marcel Gratton's Avatar
Originally Posted by jfrederick View Post
Just caulk it
Better yet, just turn the thermostat down .
On The Level Inspection
Gatineau, Québec
Old 12/8/11, 8:30 PM
Christopher Currins's Avatar
I hope not....it just looks prettier.
Christopher Currins
Certified, Licensed
Old 12/8/11, 9:11 PM
Oddly enough this is the first time I have found a burnt wire that was actually hot.
I either find them burnt and there is no temp difference, or I find them hot but no signs of schorched sheathing.
Go figure. Its not that I found the burnt wire but the fact that the image confirms that it is an active issue.
This panel was at least 30 years old. A lot can happen in 30 years.
865-256-5397
Old 12/8/11, 11:02 PM
That's right, so if it happened 30 years ago when new, has it now stood the test of time, therefore no more worries???
Old 12/9/11, 9:52 AM
Good luck with that.. I think I will call it out.
865-256-5397
News from the CPS and HUD on Chinese Drywall rhensel General Inspection Discussion 2 9/17/11 6:25 PM
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Some good questions that always need answers jtedesco1 Electrical Inspections 5 6/16/06 9:10 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
