Old 7/10/10, 12:44 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Main panel..... ground wire question
This is a pic on the inside of the garage...( opposite main panel )
Should the ground wire and as it connects to the rebarb ( entering to
to the foundation ) be covered?
This is visible from the inside of the garage.
David
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/10/10, 1:14 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Main panel..... ground wire question
Are you asking if the box needs a cover? There is no voltage present. That is simply to allow access to the connection.
Old 7/10/10, 1:21 PM
Robert Meier's Avatar
So this is a connection of a GEC to the rebar that is stubbed up above the slab for a concrete encased electrode? If so, that connection is required to be accessible if not buried in the concrete which is probably the reason that the mud ring is over it.
Old 7/11/10, 12:15 AM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not necessary to cover wire although it looks like that was the intention with installation of the mud ring to allow access to the clamp portion.
www.MauiHomeInspections.com
Old 7/11/10, 1:15 AM
Tim Spargo's Avatar
If they sheet rock this area, the mud ring will allow for a blank cover over the top of it.
Tim Spargo
Spec Rite Inspections
661-317-5770
Can a main panel be a sub if?? sfogarty Electrical Inspections 8 4/23/10 4:57 AM
Braided Ground wire in the service panel rdrangstveit Electrical Inspections 4 4/9/10 8:48 AM
Panel wiring question dmacy Electrical Inspections 12 2/2/09 8:38 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
