A 200 amp panel installed on a residential home....the
grounding wire conduit has alot of slack it and the stake is a possible trip hazard....... ![]()
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
' Where exposed, a GEC ( grounding electrode conductor) or its enclosure shall be securely fastened to the surface on which it is carried. A 4 AWG or larger GEC shall be protected where exposed to physical damage.' NEC 250.64(B)
That 'stake' is also referred to as the grounding electrode. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Unless the rod is longer than 8' the top should be flush or beneath the surface. The conductor should have straps to hold it to the surface of the building.
thanks
| Distribution and Main panel | jfrederick | Electrical Inspections | 5 | 5/4/09 6:53 PM |
