Old 7/4/09, 2:38 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default Main panel installed at floor level in garage
200 amp Wadsworth split bus. How would you all comment on the location, so close to the floor? House built in '68. Front cover had some rusting, but connections & such looked good. Also, I believe Wadsworth panels have a "secondary" or "inner" cover with top & bottom screws, correct? This one obviously didn't. Can you puchase these covers separately?
I realize there are some other issues, like the wire coming out of the front and the hose bib right above, but I'm mainly inquiring about the location.
Thanks in advance.
main-panel-installed-floor-level-garage-100-lakeview-dr.-defiance-065.jpg   main-panel-installed-floor-level-garage-100-lakeview-dr.-defiance-068.jpg
Find an InterNACHI certified California Home Inspector (and anywhere else in North America)
Old 7/4/09, 4:36 PM
gbeaumont's Avatar
Default Re: Main panel installed at floor level in garage
Hi Joshua,
The height of the panel isn't an issue, however access to it is an issue on top of the other problems you pointed out.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 7/4/09, 6:00 PM
mthomas2 mthomas2 is offline
Ignition source within 18" of garage floor.
Old 7/4/09, 6:03 PM
Jeffrey R. Pope's Avatar
That's a bit of a stretch. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/5/09, 8:25 AM
wsiegel wsiegel is offline
working clearance is the big issue
Old 7/5/09, 8:39 AM
Wayne B. Wilson's Avatar
I would say clearance , a issue . I had switch gear , sitting on the floor, in a basement so that is not a problem. I do have a question though. Panel outside mounted about 4 inches off the ground in a extreme wet area . Would anyone write it up?
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Need help with main panel board buss bar smcintire Electrical Inspections 63 1/8/08 5:55 PM
Main disconnect at meter instead of main panel. OK? kshepard Electrical Inspections 14 11/8/06 6:24 PM
