The main was installed in a closet. I had my client try to reach the main breaker.
As you can see that the panel is installed to high. The panel is a recent install. The home is a slab. What is the height requirment and panel are not allowed in closets correct? |
Max height of breakers: 6' 7"
Provide working space: 30" min side to side - 36" min in front Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
The 30" is not side to side, but overall (the dimension does not have to be centered on the panel).
. . .and can't be located in a clothes closet. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff,
How about this one? 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I see those occasionally. I just can't understand what the were thinking (or if they were thinking at all).
| Subpanel wired as main panel. | jlybolt | Electrical Inspections | 15 | 5/23/07 4:10 PM |
| Main disconnect at meter instead of main panel. OK? | kshepard | Electrical Inspections | 14 | 11/8/06 6:24 PM |
