Old 7/26/07, 1:45 PM
srodriguez srodriguez is offline
Default Main panel minimum height from floor?
What's the minimum height requirement for a main distribution panel. I know the maximum height, but can't find any information about minimum height from floor. Tomorrow I'll be looking at a panel that was installed in a dining room knee wall 18" above floor. I know it's an unsafe height, but need to know what code says.
Thanks guys
Old 7/26/07, 2:31 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Main panel minimum height from floor?
The NEC does not specify a minimum height, only the maximum height of 2 meters or 6'7" to to center of the operating handle.
Why do you feel that this height is an issue?
Old 7/26/07, 4:51 PM
Mike Whitt's Avatar
Unmoderated Guest
On anything other than a mobil home the panel must be above ground. In a mobil home the min is 24 inches off finish floor.
Now tell me that the NEC makes a lot of sense....no I did't say that!!!
The devil made me do it??
Old 7/26/07, 7:24 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
Steve the IRC states 6ft 5in from floor or any applicable state or local code
Old 7/27/07, 9:49 AM
mthomas2 mthomas2 is offline
Dennis, I think something is missing from that post...
Old 7/27/07, 10:04 AM
WHAT .....Shame on you....thehehehhe
Paul W. Abernathy
Old 7/27/07, 12:16 PM
thanks mike must be the heat
Old 7/28/07, 12:23 PM
at 17" above floor, it can be easily damaged and children can easily access.
Old 7/28/07, 12:25 PM
Thanks, Mike
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
