Could not tell what the main amperage was. Anybody know?
All branch circuits worked on inside of residence. Seems like an older panel....What would be a correct write up?
| Find an InterNACHI certified Arizona Home Inspector (and anywhere else in North America) |
More info please. Any photos?
David,
Your images did not load. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Looks like on old pushmatic. Does not appear to have a main disconnect. Is this a sub panel? Based on the number of circuits, I would say this is a 60 amp panel. I do not see a grounding bus, is this an ungrounded system?
Pioneer@homeinspectorpro.com www.pioneerconsultingllc.com https://www.facebook.com/pages/Pione...61954813862888 http://activerain.com/action/agents_secure/my_home Ask Me Why I use Home Inspector Pro Report Software Last edited by mroberson; 11/2/09 at 8:56 AM.. |
The service capacity cannot be determined with the info you have provided, but Mike is probably close. These panels were generally rated for 60 amps. The determining factors in this case are the SEC's and the panel listing.
This is an original panel to the residence, and likely to be insufficient for modern conveniences. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Distribution and Main panel | jfrederick | Electrical Inspections | 5 | 5/4/09 7:53 PM |
| Main and Sub Panel | gheller | Electrical Inspections | 10 | 9/25/08 10:22 PM |
| Main service disonnect question | jmichalski | Electrical Inspections | 5 | 1/29/06 5:32 PM |
