Old 10/4/10, 2:11 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Main panel without...Main Disconnect, need help
Unrelated to my previous post. Different house.
1988 house, 3000 sqft. The Main panel did not have a Main Disconnecting
breaker.... I searched throughout the whole house and could find sub panel
or Main breaker somewhere else.
The panel was in good condition with lots of breakers for the 3000sqft
and I did not observe any electrical problems with the Branch circuits.
What would be the recommendation?
David
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/4/10, 3:07 PM
Jeffrey R. Pope's Avatar
Default Re: Main panel without...Main Disconnect, need help
The disconnect is located behind the hinged cover, just above the meter. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/4/10, 5:07 PM
thanks....Jeff. How many amps ?
Old 10/4/10, 5:22 PM
It looks like a 200 amp GE panel, but I've seen similar models with 125A and 150A service breakers.
This is one of those times where you really should revisit the property to verify, after all, it was an over-sight on your part.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/4/10, 9:52 PM
Keith Runquist, CMI Keith Runquist, CMI is offline
Send a message via AIM to krunquist
Could be below the meter too. Behind a panel anyway.
Keith Runquist, CMI
Old 10/4/10, 10:50 PM
Thanks Jeff....good advice
Old 10/4/10, 11:02 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
yes, upper left section
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 10/4/10, 11:04 PM
Mine wasn't a guess. It's right where I said it is.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/4/10, 11:34 PM
You won't be able to see the rating when you open the cover. It's on the upper edge of the breaker-handle. I usually use a mirror to view it.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Main Panel vs Sub-Panel and main disconnect? rbassett Electrical Inspections 11 10/24/09 6:16 PM
Distribution and Main panel jfrederick Electrical Inspections 5 5/4/09 6:53 PM
Sub panel main tripping? crichiii Electrical Inspections 6 12/28/06 10:08 AM
Sub panel main tripping? crichiii Electrical Inspections 6 9/19/06 10:08 PM
