Old 7/13/08, 12:04 AM
lfoster's Avatar
lfoster lfoster is offline
Question Main on pole, Distribution in home?
Saw a home today and the service panel was at the meter on a pole. 200 Amp panel, 2/0 CU The two conductors out the bottom into smaller conduit fed the outbuildings.
The 200 Amp main breaker went to the house.
In the house, another 200 Amp panel, 3 wire feed, neutrals (grounded) and grounding mixed under the same terminal screw, and bonded.
The two panels are 50+ feet apart and were not connected by fence, etc.
To my tired train of thought,
- the interior panel needs a separate bus bar for grounding conductors
- remove bonding strap
Old 7/13/08, 12:12 AM
Jeffrey R. Pope's Avatar
Default Re: Main on pole, Distribution in home?
What type of conduit were the feeders run through - metallic or non-metallic?
Was the building/structure equipped with a grounding electrode?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/13/08, 9:11 AM
Unmoderated Guest
I just noticed this duplicate.
I replied here: http://www.nachi.org/forum/f19/main-meter-pole-distribution-home-30687/
