Old 7/27/11, 9:17 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default Main service disconnect/panel question
Having a hard time posting pic, but anyway... Do the grounds & neutrals need to be tied together at the main service disconnect? or on the same neutral bus bar?
The neutrals were separated on the main panel neutral bus bars (which were bonded w/green screw) and the grounds were on separate bus bars (which were also bonded to the panel) attached to the panel.
Thanks in advance.
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/27/11, 10:25 AM
Jeffrey R. Pope's Avatar
Default Re: Main service disconnect/panel question
As long as both are bonded to the enclosure at the service panel, it has been done properly. When they are both bonded to the enclosure, they ARE tied together.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/27/11, 10:36 AM
Thanks for the confirmation, Jeff.
Old 7/27/11, 12:41 PM
Jim Port Jim Port is offline
Unmoderated Guest
They don't need to be on the same bar in a service panel. Typically in a service panel they will be because it would cost extra to add an auxillary ground buss.
Any panel besides a service panel would require the grounded and grounding to be isolated from each other.
Old 7/27/11, 4:51 PM
Robert Meier's Avatar
Thanks in advance.
Your installation is fine as long as the panel contains the service disconnecting means and that there are no neutrals connected to the equipment grounding bus which would cause neutral current to flow on the enclosure.
Old 7/27/11, 10:22 PM
I think we're talking service equipment with the service disconnect...
Larry Kage, CMI
231 929 3525
Home Inspector Listings jbowman Miscellaneous Discussion for Inspectors 230 3/21/12 9:35 PM
Mold Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 15 1/3/12 1:14 PM
Adequate service size....oh, and a GFCI question ksherstobetoff Electrical Inspections 13 2/8/07 1:18 PM
Main service disonnect question jmichalski Electrical Inspections 5 1/29/06 4:32 PM
