Correct size wire(s) for 200 amp breaker? Anyone have wire sizing chart? Thanks in advance.
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
3/0 in Canada
NEC, 200 amps=#2/0 Copper or #4/0 Aluminum, #2 cu=125 amps, all with some restrictions. Table 310.15(B)(6)-2008 NEC.
So to answer my first question?? Is this 2/0 in the picture(s)?
Looks like #2 Copper, from photo {2 AWG}.
Again I ask, Is this the correct wire size for 200 amp breaker and/or what is the difference between #2 and 2/0?? Thanks.
Did you read post #3? The answer is no for 200 amps.
2/0 (two naught) pronounced "two not" is a larger wire and will carry the 200 amps by your codes. #2 is good for up to 125 A depending its installation, configuration e.g. in open air, in a raceway, in a 3 wire cable, etc.
#1/0=0 #2/0=00 #3/0=000 #4/0=0000 After #4/0 the wire sizes start with their circular mil area in thousands. |
naught /nɔt/ Show Spelled[nawt] Show IPA –noun 1. nothing. 2. a cipher (0); zero Last edited by Brian A. MacNeish; 7/12/11 at 10:13 AM.. |
Go to the electrical supply house here and say "I need some three naught". First they look at you really funny then they say "you must be Canadian". |
. Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| What wire size and breaker for heater??? | Dan Bolton | Inspecting HVAC Systems | 3 | 12/17/10 7:51 PM |
| 4 wire for main panel? | mnahrgang | Electrical Inspections | 2 | 8/24/09 5:54 PM |
| Wire size? | nbhi | Electrical Inspections | 50 | 3/4/08 1:10 PM |
